GISGEN failure at STEP: src/raster/r.binfer
I discovered that I don't have all the binaries compiled when I
tried to use the r.report command......
So after trying to "re"compile GRASS on Linux and run into the following......
[root@ren CMD]# GISGEN.my
GISBASE=/usr/local/grass42
SRC=/usr/local/grass42/src421/src
CMD=/usr/local/grass42/src421/src/CMD
HEADER=linux
ARCH=linux
GISGEN Wed Apr 21 17:35:57 PDT 1999
GISBASE = /usr/local/grass42
SRC = /usr/local/grass42/src421/src
CMD = /usr/local/grass42/src421/src/CMD
HEADER = linux
ARCH = linux
first step: src/raster/r.binfer
GISGEN: src/raster/r.binfer - Wed Apr 21 17:35:57 PDT 1999
/usr/local/grass42/src421/src/raster/r.binfer
  make -f OBJ.linux/make.rules
rm -f lex.c gram.c
yacc binfer.y
rm -f gram.c
mv y.tab.c gram.c
rm -f OBJ.linux/gram.o
gcc -O2 -m486 -fwritable-strings -DATT_386 -I/usr/local/grass42/src421/src/inc
lude -DUSE_TERMIO -c gram.c
mv gram.o OBJ.linux/gram.o
lex -l binfer.l
make: lex: Command not found
make: *** [lex.c] Error 127
[root@ren CMD]#
is this a makefile problem? there is still plenty of hard disk space and I
thought that someone else recently posted this problem.
What don't I have set up correctly?
Jeff.
Jeff D. Hamann
277 SE Lilly
Suite H
Corvallis, Oregon 97333 USA
541-754-3309
hamannj@ucs.orst.edu
http://ucs.orst.edu/~hamannj
Maybe you didn't have "lex" installed. On some versions it is
called flex (GNU version of the lexical analyser). To see if
you have lex or flex :
bash$ which lex
/usr/bin/lex
bash$ which flex
/usr/bin/flex
bash$ ll /usr/bin/*lex
-rwxr-xr-x 1 root bin 130620 Feb 6 1997 /usr/bin/flex*
-rwxr-xr-x 1 root bin 21 Jan 17 1995 /usr/bin/lex*
if you have flex but not lex, lex is just a shell script saying
flex -l $*
If you haven't either, look at your Linux distribution. You have to
install the package (you will also probably need yacc for compiling
some modules of Grass)
Hope this helps
Michel Wurtz ENGEES - Laboratoire Territoires & Environnement
                1, quai Koch - BP 1039, F-67070 STRASBOURG cedex
                Tel: +33 03.88.24.82.45 Fax: +33 03.88.37.04.97
