>From: samg@hanover-crrel.army.mil (Sam M. Gustman)
> We have recently had a Silicon Graphics machine added to our network
>filled mostly with SparcStations. I would like to use the GRASS SGI
>modules on the SGI and have the graphics exported to my Sun. Has anyone
>heard of a GL to X protocol converter? I assume such a program would
>sit on top of the X-Server and translate the GL graphics to X-Bitmaps.
>Any information would be appreciated.
SGI's run X11R4 (same as Sun, but w/ different window manager which is
not too relevant). Running X stuff on the Sparc, using the SGI as the
display is not much of a problem, but going the other way is, since
our SGI is a 24-bit system and our Sparc only supports 8-bit graphics display,
so the SGI applications which expect a 24-bit display refuse to run
when asked to display on the Sparc. If you have 24-bit displays on the
Sparcs, I think it should all work fine. SGI integrated GL and X
quite awhile ago (I forget which sits on which).
(I am assuming you mean that you want to use the Sparcs as X-terminals
to the SGI. If you just want to do image file conversion, the SGI comes
with many conversion utilities.)
She surveyed seafloors | Donna Okazaki
to the seashore ~ ~ ~ ~ | Univ. of Hawaii, Geography Dept.
but not anymore | donna@uhunix.uhcc.hawaii.edu
| ph: (808)956-3526 fax: (808)956-3528
