1) I just recently acquired GRASS 4.0 and got it installed on my system. With it I got the 'global' and 'spearfish' data sets. The 'spearfish' set is fine, but I cannot access the 'global' data set. When I start GRASS and select the 'global' location and start the display monitor, I get the following messages:
Mapset <david> in Location <global>
GRASS-GRID > d.mon start=x0
Graphics driver [x0] started
ERROR: region for current mapset is invalid
<projection field missing>
run "g.region"
Problem selecting x0. Will try once more
run "g.region"
GRASS-GRID > g.region
ERROR: default region is not set
GRASS-GRID > g.region -d
GRASS-GRID > g.region region=default
ERROR: region <default> not found
GRASS-GRID > g.region -p
ERROR: Invalid region: Illegal n-s resolution value
GRASS-GRID > g.region -g
What am I doing wrong?
2) I recently saw that the 'imagery' data set was loaded to moon.cecer.army.mil and I downloaded it, but cannot figure out how to use it. Any tips?
Thanks in advance.
David C. Wyatt Tel. (410) 964-3293
Meridian Sciences, Inc. FAX: (410) 964-3295
6430 Dobbin Road, Suite D e-mail: david@sport.mersci.com
Columbia, Maryland 21045
