Ronald Thomas (ront@meeker.cfnr.colostate.edu) writes:
The 650C can plot its own raster language, (HP Raster Transfer Language)
and finding a software package that converts to it (from sunrast, gif, ps,
however you save images now) might be cheaper than the
$1125.00 upgrade the plotter requires to plot postscript.
From a document provided via Hewlett-Packard's "HP First"
fax retrieval system (800-333-1917):
Document #5535:
File Conversions for the HP DesignJet Plotter
(apparently last updated August 1992)
"The HP DesignJet plotter directly supports three kinds of files
common in many CAD and graphics applications:
* HP Raster Transfer Language (HP RTL)
* HP-GL/2
* HP 7586B emulation (HP-GL)
"If your application does not support one of the HP DesignJet internal file
types, you can still plot by using a third-party utility to translate your
file into a compatible format."
The document then has a table that "lists many common plot file formats
and the third-party utilities that can convert these files to HP RTL
for plotting on your HP DesignJet plotter."
IMAGE ALCHEMY and FREEDOM OF PRESS are two of the packages listed. They are
the ones listed that run on Sun platforms. The others that are listed are
exclusively for DOS.
IMAGE ALCHEMY, according to the HP chart, can convert these file types
to HP RTL:
CALS-CCITT G4 Type 1
GIF
SGI Raster Files
Sun Raster Files
Targa
TIFF Packbits
FREEDOM OF PRESS, according to the HP chart, can convert these file types
to HP RTL:
PostScript
The HP document then lists platforms that are supported by the listed conversion
software packages.
IMAGE ALCHEMY:
Sun 3
Sun 4
Sun SPARCstation
RS/6000
FREEDOM OF PRESS:
Sun SPARCstation
Again from the HP document:
"For more information, contact the individual manufacturer of the third-party
utility you are interested in."
Image Alchemy
Handmade Software
15951 Los Gatos Boulevard
Los Gatos, CA 95032
408-358-1292
Freedom of Press
Professional Series
Custom Applications, Inc.
900 Technology Park Drive
Building 8
Billerica, MA 01821
508-667-8585
800-873-4367
Scott Wade wade@vinny.cecer.army.mil
unofficial comments - my words, not my employers' !
no recommendations or guarantees implied - just passing along info !
all info here is from Hewlett Packard
