Hello GRASS Users,
I am attempting to run GRASS4.1 under Red Hat Linux version 4.0 which I have
recently acquired. Linux works great but I am experiencing a problem when
trying to call up a graphics monitor with the "d.mon start=x0" command.
When I issue the command the system returns the following error message:
X error of Failed Request: BadMatch (invalid parameter attributes)
Major opcode of failed request: 78 (X_CreateColorMap)
Serial number of failed request: 25
Current Serial Number in output stream: 26
Error-could not complete locking process for monitor x0
Lock file is /usr/grass/locks/localhost/mon.100482
Problem selecting x0. Will try once more.
I have heard that a couple of library files are needed to properly run GRASS
(libX11.so.3 and libXT.so.3.1.0) and I have put them into these directories
under "grass" ownership:
/usr/lib
/usr/X11R6/lib
/usr/X11/lib
/usr/grass/driver
Can anyone tell me where I am going wrong and or how to fix this problem?
Any assistance is much appreciated.
-Dave Viebrock
/usr/lib
/usr/X11R6/lib
/usr/X11/lib
/usr/grass/driver
Dave:
The "standard" GRASS 4.1 XDRIVER ONLY works with X-Servers running in
8-bit (256 Colour Mode). The above probably indicating that you are
running your Red Hat 4.0 Server in a 15/16 or 24 bit Colour Mode? Moving
back to the 8-bit mode should get GRASS's XDRIVER working for you!
Lawrence Houston - (houston@boyd.geog.mcgill.ca)
The question is: Is there a patched version of XDRIVER which supports
15/16 bit colour mode? This seems to become a FAQ in Linux environments.
Henning
Henning Brockfeld mailto: Brockfeld@wigeo.bwl.uni-muenchen.de
Institut f"ur Wirtschaftsgeographie Universit"at M"unchen
http://www.wigeo.bwl.uni-muenchen.de/~hbrock/
Henning:
On 8 Apr 1994 Kenn Gardels <gardels@ced.berkeley.edu> makes reference to
24-bit patches being available as part of their Alpha Port:
ohlone.ced.berkeley.edu:/pub/grass
Again on 16 Feb 95 Kenn makes reference to the Alpha patches, but this
time ONLY mentions contacting him via E-mail?
On 17 Feb 1995 Andreas Schmidt <schmidt@ipf.bau-verm.uni-karlsruhe.de>
reports that Kenn's 24-bit patches work under SunOS (24-bit display) and
Linux (24-bit & 16-bit displays).
Not sure if the "patches.xdriver.24bit" patch contained in
"grass-alpha-axp-0.6.tar.Z" is the most recent (Mar 25 1995), your might
want to check with Kenn on that. Additionally I have NOT tired these
patches myself (ONLY kept the GRASS Hopper Posting related to them), but
reportedly they allow for an 8-bit XDRIVER Window to operate on a
16/24-bit display. Hope that helps?
Lawrence Houston - (grass@boyd.geog.mcgill.ca)
