Hi:
Can someone tell me if a driver, other than those included, is needed to
run GRASS4.1 on a Sun Sparc2 with a 24-bit RasterOps card, or are there
modifications that need to be made to use the included drivers? The problem
occurs when running d.mon.
Thanks
Are you running XGRASS? X deals with 24 bit color differently than 8 bit
color. The two are not compatible (e.g you can not get software that is
written for 8 bit to run on a system using 24 bit color). If I am wrong
then someone explain to me how it is done.
Pat McClanahan Internet:mcclanah@dlgeo.cr.usgs.gov
EROS Data Center mcclanah@edcserver1.cr.usgs.gov
Sioux Falls, SD
605-361-4607
