Graphics Monitor Problem
I just downloaded and installed the grass binary for Solaris on my
Sparc 5 and get the following error when I try to start a monitor. Can someone tell me what the
trouble is?
TIA,
-Jim
GRASS-GRID > d.mon start=x0
X Error of failed request:  BadMatch (invalid parameter attributes)
  Major opcode of failed request:  78 (X_CreateColormap)
  Serial number of failed request:  269
  Current serial number in output stream:  270
Please start graphics monitor <x0>.
Error - Graphics monitor <x0> not running!
Problem selecting x0. Will try once more
jcurry@llnl.gov    | James Curry
925.423.1106 voice | Lawrence Livermore National Laboratory
925.423.6775 fax   | P.O Box 808, MS:L-183
                   | Livermore, California  94550
At 10:07 AM 7/20/99 -0700, you wrote:
trouble is? TIA,
-Jim
        <<<<x0> not running!
                              94550
Did you create a monitorcap file, and did your setup create the nodes for
fifo.1a etc in the correct directory? I got errors like this when I failed
to do these two things from a source install under Linux.
Yes, I have a monitorcap file and the fifo.1a and others are in the gbase/dev directory.
The error seems to indicate some kind of color map problem.
Hi
for the X_CreateColormap please check the FAQ:
  http://www.geog.uni-hannover.de/grass/grass_faq.html
  -> d.mon problems: X Error 78 (X_CreateColormap).
It is related to the XDRIVER you are using and the color depth
(8bit/24bit).
Best regards
  Markus Neteler
On Tue, 20 Jul 1999, James Curry wrote:
trouble is?
Dear all,
i find the X graphic monitor have
terrible radiometric resolution.
Can anyone help me improve this.
I also have tried X24 driver.
Rgds,
