Hello,
Just a quick question - I was under the impression that GRASS can import
generate, export and display 24 bit images - is this correct ?
Cheers, Al.
Found this in my archives:
According to Kenn Gardels:
> We have modified the GRASS code to work on a 24bit display directly, by chec
king
> first for a psuedocolor or truecolor visual. It works fine on DEC Alpha, bu
t
> we havn't tested it on other platforms.
It works also fine on SUN (SunOS) with 24bit and on LINUX with 24bit
and 16bit!Andreas Schmidt
FYI.
Nancy Taaffe USACERL
