I am trying to create my first GRASS dataset using the following parameters but GRASS will not create the Location:
Mapset: airshow
Database: /users/smieg/data
GRASS asks me if I "Would you like to create location airport (y/n)?"
I answer <y>.
I get a "(y/n)" prompt as a response.
I answer <y>.
GRASS replies "Location <airport> not created. Hit RETURN -->"
The permissions on /users/smieg/data are 777.
Any help would be appreciated.
Andy
______________________________________________________
Get Your Private, Free Email at http://www.hotmail.com
Where can I find an "install grass 5 how-to"? I'm a novice in linux and I
have had some difficult to try to install grass 5.
thank you very much,
The GRASS-download file having been downloaded, you have to use gunzip and
tar comand to install file. After that, you should find install guide in
somewhere around here.
Try again,
Taravudh.
How can I determine the resolution of dlg data? I have gotten the
edges in UTM format from the file. Can I derive the "resolution" (as
required to initialize the GRASS location) as well as other parameters from
this information?
I have found some dlg format information on the net. It is widely scattered
though.
Alan Davis
Alan E. Davis Marianas High School (Science Department)
AAA196, Box 10001 adavis@netpci.com http://www.saipan.netpci.com/~adavis
Saipan, MP 96950 15.16oN 145.7oE GMT+10 Northern Mariana Islands
