Hi *
I have a patch for GRASS 5.0 on Linux/Alpha at:
http://grasshoppernet.com/~bhughes
With this patch applied, GRASS 5.0 compiles and runs
on Alpha Linux, with minimal compiler warnings and no
segmentation violations. (Yet.)
It's a substantial patch, but the size is mostly due
to the effects of running 'cproto' on the 'src/libes'
files to create ANSI prototypes. This patch also adds
appropriate headers where malloc- signal- and str-
family functions are called. All of this is to help
find those 'default int' calls that break so badly
in 64-bits.
There _are_ some actual code fixes in there, too. None
of them are 64-bit specific - mostly they fix calls with
with the wrong number of arguments, or improper types.
Bill Hughes
