I used v.out.ascii command to export grass data that just presented in
x,y coordinate.
Ex..
A 5
xxxxxx yyyyyy
xxxxxx yyyyyy
xxxxxx yyyyyy
xxxxxx yyyyyy
xxxxxx yyyyyy
A 4
xxxxxx yyyyyy
How should I get the attribute of this vector file from grass? Where is
it? and How to link these attributes with x,y coordinate in case of
polygon data.
Thank you,
Taravudh
x,y coordinate.
[snip...]
polygon data.
vector files contain only geometry of lines and a letter for the type
(A = Area, L = Lines). The attributes are (in ascii) in the dig_att
directory (same name as vector file) and look like :
A xxxxxx yyyyyy nn
where xxxxx and yyyyyy are the coordinates of a point inside the
polygon and nn is the attribute.
When you have more attributes, they are in the dig_cats directory
(same name as vector file)and look likes a raster cat file
(list of couples att_number:cat_number
Michel Wurtz ENGEES - Laboratoire Territoires & Environnement
1, quai Koch - BP 1039, F-67070 STRASBOURG cedex
Tel: +33 03.88.24.82.45 Fax: +33 03.88.37.04.97
