GRASS colors
From grass-lists-owner@max.cecer.army.mil Mon Aug 22 13:05:08 1994
Received: from zorro.cecer.army.mil (zorro.cecer.army.mil [129.229.1.6]) by diego.cecer.army.mil (8.6.9/8.6.9) with ESMTP id NAA25154; Mon, 22 Aug 1994 13:05:03 -0500
Received: from amber.cecer.army.mil by zorro.cecer.army.mil (8.6.9) id NAA22279; Mon, 22 Aug 1994 13:04:55 -0500
Received: from max.cecer.army.mil by amber.cecer.army.mil (4.1/SMI-4.1)
  id AA15038; Mon, 22 Aug 94 13:02:49 CDT
Received: from pike.cecer.army.mil (pike.cecer.army.mil [129.229.32.28]) by max.cecer.army.mil (8.6.9/8.6.9) with ESMTP id NAA07055 for <grassu-people@max.cecer.army.mil>; Mon, 22 Aug 1994 13:02:50 -0500
Received: from amber.cecer.army.mil (amber.cecer.army.mil [129.229.32.40]) by pike.cecer.army.mil (8.6.9/8.6.9) with SMTP id NAA14306 for <grassu-people>; Mon, 22 Aug 1994 13:02:49 -0500
  id AA15032; Mon, 22 Aug 94 13:02:44 CDT
Received: from canopus.CC.UManitoba.CA (root@canopus.cc.umanitoba.ca [130.179.16.24]) by max.cecer.army.mil (8.6.9/8.6.9) with SMTP id NAA07052 for <grassu-list@moon.cecer.army.mil>; Mon, 22 Aug 1994 13:02:45 -0500
Received: from pollux.cc.umanitoba.ca by canopus.CC.UManitoba.CA
  (4.1/25-eef) id AA25341; Mon, 22 Aug 94 13:02:27 CDT
Received: by pollux.cc.umanitoba.ca
  (4.1/25-eef) id AA09211; Mon, 22 Aug 94 13:02:28 CDT
Date: Mon, 22 Aug 94 13:02:28 CDT
Message-Id: <9408221802.AA09211@pollux.cc.umanitoba.ca>
Sender: grass-lists-owner@max.cecer.army.mil
Reply-To: grassu-list@max.cecer.army.mil
Precedence: Bulk
Status: R
Dear Grass-users ,
The following question of mine is beyond GRASS works, but in future
it need GRASS works in various its application, in my opinion.
Q: In GRASS, just 0-255 integer rast-based color coding image is possible,
   but how about dynamic range color/gray scale image with real number?
   Is possible now in GRASS ?
   If not, anyone know Unix-based gray scaling and image generation software
   and its ftp site ?
   Actually, at XV( ver 3.0), I handled gray image after assignment into
   proper integer number from real number, but some loss of original information...
Looking forward help...
Thanks in advance.
                                                           Kiwon
ps; I must express my thanks to M. Ameskamp, J. D. McCauley, and J. L. Aycrigg
    for their advice about my previous question. Now no problem, work out.
Using GRASS color files, you can specify values from 0-255 for EACH
of the three (red,green,blue) color components, yielding something
like 16 million possible colors. Of course, the problem comes in
trying to display your map. There are severe limitations with the
GRASS X-driver and with 256 color 8-bit monitors. But even with
24-bit displays, the GRASS X-driver still limits you to something
like 216 colors. (I understand that the tcl/tk viewer will let you
use all your available color depth). But for now, if you have a
display device capable of more colors, you could use r.out.ppm to
convert the GRASS raster file into a 24-bit ppm image, then output
that.
And just a reminder that if you're running on an SGI with 24-bit
graphics, don't overlook the IRIS monitor driver, which will give
you 3840 colors.
-Bill
