GRASS CVS server backup - was Re: [GRASS-dev] env variables not set
On Jan 7, 2008 9:38 PM, Glynn Clements <glynn@gclements.plus.com> wrote:
Markus Neteler wrote:
> > > I don't know if this is a local problem with my setup, but for some time
> > > now, MAPSET, LOCATION_NAME, and GISDBASE are not defined anymore in a
> > > running GRASS session. Just recompiled with fresh svn checkout, and the
> > > problem persists.
> > > This means that I can't do things like
> > > database=$GISDBASE/$LOCATION_NAME/$MAPSET/dbf/
> > > I don't see any relevant changes in lib/init/init.sh which could explain
> > > this, but before I dig deeper to find out what's going on I would like
> > > to hear whether anyone else has this problem.
> > This was changed years ago (in 5.x, AFAICT; there doesn't appear to be
> > any way to obtain the revision history for 5.x now that CVS is gone).
> You can: example:
> cd lib/gis/
> svn log key_value1.c
> r23436 | glynn | 2007-04-15 01:02:01 +0200 (Sun, 15 Apr 2007) | 4 lines
> Use "const" where appropriate
> Use (void) instead of () for empty parameter lists
> Use full type for function pointers
> r13833 | bernhard | 2004-11-09 13:18:56 +0100 (Tue, 09 Nov 2004) | 2 lines
> copied within CVS repository from grass/src/libes/gis/key_value1.c
> r9499 | markus | 1999-12-29 16:10:05 +0100 (Wed, 29 Dec 1999) | 2 lines
> Initial revision
It only goes back to 2002 for lib/init/init.sh. In 5.x, that file was
at src/general/init/init.sh.
Also, AFAICT you can't distinguish 5.x history from 6.x. There are SVN
branches for the 5.x CVS release branches, but not for the trunk.
Good point.
> If you want a ChangeLog file, just get 'svn2cl', see
> http://trac.osgeo.org/grass/wiki/HowToSVN
> Also: The CVS should still work (and the old ChangeLog files are available).
There is no CVS server on cvs.intevation.de:2402 any more.
Interesting! It disappeared silently.
Is anonymous (pserver) CVS still functional?
No idea. But the copy from Martin Landa looks good:
http://josef.fsv.cvut.cz/cgi-bin/viewcvs.cgi/?root=grass-cvs-2007-12-09
I also have a full backup copy (offline) available.
