GRASS d.mon
Hello, for some reason when I run d.mon from an xwindows terminal
windows I can start a monitor but I cannot select any monitor that I
have started. Consequently, I cannot run any programs which require a
selected monitor. Even when I specifically select a running monitor
from the command line the changes do not seem to take hold and I cannot
run a monitor-dependant program.
If someone could post a response I would appreciate it.
