Hello ,
I am now trying to install a GRASS on DEC 5000 and Ultrix system
after intallation I was starting grass4.0 - and
I did get a following message -sh:g.gisenv : not found
sh : GISDBASE :parameter not set--
I was doing evething as before on SUN ( where all is fine ).
thnaks - Peter Sincak
PS.> I admit - I am new in this instalations - maybe it is very
small problem.
First, make sure you run the MAKE.LINKS command after the compile is
done. Second, I had to edit etc/GIS.sh to change the syntax for the
test command to legal Ultrix (I don't remember off the top of my head
- mail again if you can't figure it out).
-kenn
| Kenn Gardels Tel +01 (510) 642-9205 Fax +01 (510) 643-5571 |
| CEDR - 390 Wurster Hall Internet gardels@ced.berkeley.edu |
| University of California Bitnet gardels@UCBCED |
| Berkeley, CA 94720 Calendar gardels@tahoe.ced.berkeley.edu |
