[GRASS-dev] #1036: empty monitor in i.pr.classify
Greetings
I have testes this function and even with "black" panels it does work and saves a few signature files. The thing is that the rasters are not displayed in x0 monitor. Does anyone knows what might not be ok or what libraries/packages am I missing?
Antonio
__________ Information from ESET NOD32 Antivirus, version of virus signature database 5033 (20100416) __________
The message was checked by ESET NOD32 Antivirus.
http://www.eset.com
2010/4/16 António Rocha <antonio.rocha@deimos.com.pt>:
Greetings
AFAIK i.pr.* was written for GRASS 5.x by my former colleague.
It is almost certain that more code updates are needed to use
it with GRASS 6.
To achieve this, you need to compare similar modules in GRASS
6 with i.pr.* code. Certainly the modules are different, but yet they
will be quite similar concerning the I/O and display functions
which is the part which likely lacks updates.
Greetings
Regarding this problem I decided to compare r.le.setup function with i.pr.classify to identify what might not be working-
Apparently everything seems to be working but, in the case of r.le.setup the dispay in the panel is defined by #include <grass/display.h> and in the case of i.pr.classify it uses a graphics.c function. Has anyone some experience in dealing with this displays functions in order to identify why i.pr.classify is not properly displaying rasters in the xterm.
Thanks
Best regards
Antonio
Greetings
it with GRASS 6.
__________ Information from ESET NOD32 Antivirus, version of virus signature database 5040 (20100419) __________
http://www.eset.com
__________ Information from ESET NOD32 Antivirus, version of virus signature database 5042 (20100419) __________
http://www.eset.com
