Is there some way I've missed to change 2D points with a z attribute field, into 3D points without reimporting them?
Micahel
______________________________
Michael Barton, Professor
Professor of Anthropology
Director of Graduate Studies
School of Human Diversity & Social Change
Arizona State University
Tempe, AZ 85287-2402
USA
It doesn't seem to. I think it makes columns from the points. I just want the points in 3D xyz space.
Michael
USA
> Micahel
Dylan:
v.extrude... not sure if it works with points yet.
"points become 3D vertical lines, lines to 3D lines, boundaries to
faces and areas to faces and kernel"
If there is no way how to convert 2D point to 3D points there could be
special flag for this(?)
It would seem that this would be an increasingly common task. I know that I've run into it several times lately. Most recently, I've needed this to convert 2D points to 3D to run through v.surf.bspline. It doesn't seem to work correctly using the column option, but does very nice interpolations using 3D points.
Michael
USA
If the input is a 3d point it makes a vertical 3d line out of it (the lines's 2d length = 0, 3d length = 0 + input 3d point's z). As the manual says. It takes 2 additional commnads to extract the top node:
However, the 1st solution will take as long (maybe longer) than importing the points from their original file again. I'll see if v.transform will do it in one step.
Michael
C. Michael Barton, Professor of Anthropology
On Feb 29, 2008, at 12:14 AM, Maciej Sieczka wrote:
Michael Barton pisze:
That should work but it may not exactly be easy to locate for a
novice user.
How about a little wrapper script for v.transform that simplifies
this action?
I am increasingly concerned about the number of, sometimes basic,
geoprocessing functions that are present in GRASS but "hidden"
in complex module options. Of course people can always mail to
this list but in the first place it will create frustration for
them and possible turn them away.
Benjamin
Benjamin Ducke, M.A.
Archäoinformatik
(Archaeoinformation Science)
Institut für Ur- und Frühgeschichte
(Inst. of Prehistoric and Historic Archaeology)
Christian-Albrechts-Universität zu Kiel
Johanna-Mestorf-Straße 2-6
D 24098 Kiel
Germany
novice user.
this action?
So we make little wrapper scripts like v.dissolve and v.centroids.
That's much better than dealing with code duplication.
but that shouldn't wrap 3 module commands together with temporary maps
etc to perform something as simple as the 2d+attr column -> 3d points
conversion. If as Maciek suggests v.transform could do the job then
it's not so bad. The v.transform name even sounds right for the job.
Hamish
____________________________________________________________________________________
Never miss a thing. Make Yahoo your home page. http://www.yahoo.com/r/hs
On Saturday 01 March 2008 10:20:45 pm Hamish wrote:
> novice user.
> this action?
Hamish
I agree that we should avoid code duplication at any cost, and v.transform
does the job. However, doesn't it make more sense to put that code (for
points) into v.extrude ? Or, is v.extrude primarily for areas by design?
On Thu, Feb 28, 2008 at 11:26 PM, Michael Barton <michael.barton@asu.edu> wrote:
I did it like this (borrowed from 3rd GRASS book, p. 211 - NC data set):
# work on map in current mapset
g.copy vect=precip_30ynormals,precip_30ynormals_tmp
v.info -c precip_30ynormals_tmp
v.db.addcol precip_30ynormals_tmp \
col="x double precision, y double precision"
v.to.db precip_30ynormals_tmp option=coor col=x,y
# we assume that the table name corresponds to input map name
v.in.db precip_30ynormals_tmp out=myprecip_30ynormals \
x=x y=y z=elev key=cat
v.db.select myprecip_30ynormals
# We can now remove the superfluous 'x' and 'y' columns from the table:
v.db.dropcol myprecip_30ynormals col=x
v.db.dropcol myprecip_30ynormals col=y
v.info -c myprecip_30ynormals
v.info myprecip_30ynormals
g.remove vect=precip_30ynormals_tmp
# The new map myprecip_30ynormals now contains 3D geometry.
As far as I am aware, the term "extrusion" is pretty well defined
as the operation of extending an object in 3D space by "pulling
it out" with a predefined bearing and length. This would convert a point
to a line, a line to a plane and a polygon to, well, a polygon with a
volume, I guess.
Personally, I'd be more in favour of wrapping a little script
"v.points.to.3d" around v.transform. For the beginners' sake.
Benjamin
novice user.
this action?
Hamish
I agree that we should avoid code duplication at any cost, and v.transform does the job. However, doesn't it make more sense to put that code (for points) into v.extrude ? Or, is v.extrude primarily for areas by design?
Dylan
Archäoinformatik
D 24098 Kiel
Germany
volume, I guess.
Benjamin
Well from that 'angle' I think that it makes sense not to use v.extrude.
v.points.to.3d seems like a fine choice.
Dylan
>>> novice user.
>>> this action?
>> Hamish
> by design?
> Dylan
> point to a line, a line to a plane and a polygon to, well, a
> polygon with a volume, I guess.
Dylan:
v.extrude.
'til now we have manged to keep the "."s in official modules to a max
of two.
It doesn't match v.to.rast,v.to.rast3 naming, but I think v.to.points3
would make it too close to v.to.points which is another task
completely.
But it is not so far from what v.to.rast3 does, so maybe not so bad.
(shrug)
to get a nifty instant prefab wrapper script do:
v.transform --script
Changing topic slightly, how about adding a -z flag to v.to.points for
3D lines? (no DB column involved)
Dylan:
> v.extrude.
of two.
Right-- better to stick to established conventions. Any name is ok with me.
v.points.3d sounds good.
completely.
(shrug)
