using GRASS I found a series of small parser issues:
# in and out name are identical and r.buffer happily overwrites:
r.buffer channel2_thin out=channel2_thin dist=200 --o
Reading input map (channel2_thin) ...
100%
Finding buffer zones ...
100%
Writing output map (channel2_thin) ...
100%
# while the WARNING isn't really helpful, it should just pick
# morph (which *is* in neteler, my current mapset) and go ahead:
r.mapcalc 'corridor=if(morph == 3 || morph == 5,1,null())'
WARNING: 'cell/morph' was found in more mapsets (also found in neteler).
ERROR: 'cell/morph' was found in more mapsets (also found in neteler).
# --o doesn't have an effect:
r.surf.fractal out=landscape1 --o
Steps=1
ERROR: Raster map [landscape1] exists.
Please try another
I could not find where these problems originate from.
great. I thought that I grep'ed for 'Please try another' but apparently
in a different
directory
Looks good to me, please submit.
ok,
Martin
thanks
Martin Landa wrote on 11/17/2006 06:33 PM:
> Hi Markus,
> 2006/11/17, Markus Neteler <neteler@itc.it>:
> [snip]
> just trying to fix local problem in r.surf.fractal, see the attached
> patch.
>> Steps=1
>> Please try another
> Best regards, Martin
