Hi Ben,
2009/9/30 Benjamin Ducke <benjamin.ducke@oxfordarch.co.uk>:
That looks very straight-forward. I don't know Python
either, though.
Could you write a little example script that runs the
VTK Delaunay 2D filter on a GRASS points map, as well?
Here we are:
http://code.google.com/p/vtk-grass-bridge/source/browse/trunk/Examples/v.delaunay2d.py?spec=svn24&r=24
Best reagards
Soeren
btw:
Some additional informations:
The help:
GRASS 7.0.svn (nc_spm_08):~/src/vtkGRASSBridge/vtk-grass-bridge/Examples
python v.delaunay2d.py --help
Description:
Delaunay 2d triangulation using the vtkDelaunay2D class. The created
triangles will be converted into the grass vector feature face.
Keywords:
vector, delaunay
Usage:
v.delaunay2d.py [-tw] input=name output=name [alpha=alpha]
[tolerance=tolerance] [--overwrite] [--verbose] [--quiet]
Flags:
-t Build vector topology
-w Write the triangulated map as vtk xml file to the current
working directoy named <output>.vtk
--o Allow output files to overwrite existing files
--v Verbose module output
--q Quiet module output
Parameters:
input Name of input vector map
output Name for output vector map
alpha Specify alpha (or distance) value to control output of
this filter. For a non-zero alpha value, only edges or triangles
contained within a sphere centered at mesh vertices will be output.
Otherwise, only triangles will be output.
default: 0
tolerance Specify a tolerance to control discarding of closely
spaced points. This tolerance is specified as a fraction of the
diagonal length of the bounding box of the points.
default: 0
Now some Computation.
VTK version with topo and vtk xml output:
time python v.delaunay2d.py input=elev_lid792_randpts@user1
output=delaunay2d --o -tw
Vector map <delaunay2d> already exists and will be overwritten
Building topology for vector map <delaunay2d>...
Registering primitives...
11912 primitives registered
35736 vertices registered
Building areas...
100%
0 areas built
0 isles built
Attaching islands...
Attaching centroids...
100%
Number of nodes: 5773
Number of primitives: 11912
Number of points: 0
Number of lines: 0
Number of boundaries: 0
Number of centroids: 0
Number of faces: 11912
Number of areas: 0
Number of isles: 0
real 0m1.750s
user 0m1.564s
sys 0m0.144s
VTK version without topo and vtk xml output:
real 0m1.167s
user 0m1.004s
sys 0m0.144s
Comparsion to v.delaunay with huge map, notice its a 3d vector map:
VTK version without grass topology build:
time python v.delaunay2d.py input=elev_ned10m_cont10m
real 0m27.422s
user 0m25.230s
sys 0m1.904s
VTK version with grass topology build:
369281 primitives registered
1107843 vertices registered
Building areas...
100%
0 areas built
0 isles built
100%
Number of nodes: 151776
Number of primitives: 369281
Number of points: 0
Number of lines: 0
Number of faces: 369281
Number of areas: 0
Number of isles: 0
real 0m45.035s
user 0m42.243s
sys 0m2.464s
Now the grass version:
time v.delaunay input=elev_ned10m_cont10m@user1 output=delaunay2d
--o
WARNING: Vector map <delaunay2d> already exists and will be overwritten
0 primitives registered
0 vertices registered
Building areas...
0 areas built
0 isles built
Number of nodes: 0
Number of primitives: 0
Number of points: 0
Number of lines: 0
Number of areas: 0
Number of isles: 0
Number of nodes: 0
Number of points: 0
Number of lines: 0
Number of areas: 0
Number of isles: 0
real 0m0.053s
user 0m0.028s
sys 0m0.020s
That was fast! Well looks like v.delaunay only works with 2d vector maps???
Ben
----- Original Message -----
From: "Soeren Gebbert" <soerengebbert@googlemail.com>
To: "Benjamin Ducke" <benjamin.ducke@oxfordarch.co.uk>
Cc: "GRASS developers list" <grass-dev@lists.osgeo.org>
Sent: Tuesday, September 29, 2009 5:38:12 PM GMT +01:00 Amsterdam / Berlin / Bern / Rome / Stockholm / Vienna
Subject: Re: [GRASS-dev] 3D Vector to Voxel
You don't need to learn C++. You can use Python or Java to connect
grass, vtkGRASSBridge and VTK.
And even TCL/TK if im going crazy and support the vtkTckTkWrapper.
A simple Python example which will work right out of the box:
http://code.google.com/p/vtk-grass-bridge/source/browse/trunk/Examples/r.gauss.smooth
On command line call within the nc dataset:
python r.gauss.smooth input=lsat5_1987_10 output=test --o
Thats all
Beń
Sent: Tuesday, September 29, 2009 2:49:53 PM GMT +01:00 Amsterdam / Berlin / Bern / Rome / Stockholm / Vienna
Hello Ben,
2009/9/21 Benjamin Ducke <benjamin.ducke@oxfordarch.co.uk>:
I just saw a little GPL'd sofwtare that may provide a base for
a v.to.r3 module that could actually cast arbitrary vector geometries
to a voxel grid:
Have a look at the vtkVoxelModeller class :
http://www.vtk.org/doc/release/5.4/html/a01861.html
or the vtkImplicitModeller class:
http://www.vtk.org/doc/release/5.4/html/a00859.html
Booth classes convert arbitrary datasets to a voxel representations.
I have just committed a grass vector topology reader to the vtkGRASSBridge
repository.
Maybe you can now create voxel representations of 3d grass vector
data, using GRAS, VTK and vtkGRASSBridge?
Best regards
Soeren
http://www.cs.princeton.edu/~min/binvox/
maybe someone would like to look at possibilities for integrating
this into GRASS?
Best,
Ben
Files attached to this email may be in ISO 26300 format (OASIS Open Document Format). If you have difficulty opening them, please visit http://iso26300.info for more information.
grass-dev mailing list
