Hello,
Does anyone know of or even have Ubuntu debs of GRASS 6.2.2 for Dapper ?
Even better if QGIS 0.8.1 was also available...
Moritz
Hello,
Moritz
I think basically backports sources for etch at backports.org can be used
without major issues also for Dapper. I think 0.8.1 will be available
within a reasonable time also, after entering lenny.
Francesco P. Lovergine
Even better if QGIS 0.8.1 was also available...I think basically backports sources for etch at backports.org can be used
backports has GRASS 6.2.1, not 6.2.2. That is in Sid, don't know how long it will take to get into lenny and then to get backported...
QGIS is completely absent from backports, and Sid has 0.8.0... How long do you think it will take for 0.8.1 to appear in lenny ? 0.9.0 is about to come out as well...
Moritz
Backports.org is limited to what's present in testing at the time of building.
That avoids major breakages with unsufficiently tested stuff.
If you need on-the-edge programs you need sid.
