I have seen a set of fixes in the CVS which haven't been backported
yet. So far I didn't figure out the magic line to push a fix
from HEAD to release branch.
Anyone who can teach me? Glynn once posted it but it didn't
seem to work for me.
Certainly it would be better is *all* developers made use of
the magic push line to avoid that others accidentally port
irrelevant stuff or simply to save us/me time.
yet.
Is there a policy for 6.3.0 backports? Bugfixes only? Minor fixes? New
features? Cool stuff? Everything?
Perhaps not the perfect way, but
- commit change in HEAD
- cd releasebranch_6_3/
- cvs co -r releasebranch_6_3 grass6/file/to/change
# IFF there has not been previous changes to the file in the branch
- cvs up -j HEAD grass6/file/to/change
- cvs diff grass6/file/to/change
- cvs commit grass6/file/to/change
If there have been prior changes to the branch you need to also specify the
release branch revision, as detailed in Glynn's prior post. Otherwise you get
conflicts during the merge. In those cases I admit that I usually revert to
doing a surgical edit in vi + cvs diff rather than try to make sense of the
mixed lineage. The downside is this requires a human & thus some level of human
error may be introduces.
FWIW, my strategy has been to backport bug fixes only and if there are a series
of changes wait for the dust to settle and backport all the changes at once
instead of for each of a series of refinements. The downside is sometimes after
a couple of days of settled dust I forget about it...
For recent MS Windows fixes, I think it is ok for 6.3.0 to be considered alpha1
release, and 6.3.1 can be alpha2. Do we backport all DOS changes or split off
6.3.1(MS-alpha2) as another branch from HEAD?
This normally works (from the branch):
cvs update -j HEAD <filename>
cvs commit <filename>
There can be problems if you want to merge a file more than once after
it has been branched, but I don't recall whether it affects the case
of merging from the trunk to a branch (the CVS documentation only
covers merging a branch into the trunk).
Using two -j flags with explicit revision numbers will always work,
but that's awkward for changes which span multiple files. I have had
problems with the "-j branch:date" form; an alternative is to tag by
date then merge using the tag.
As a fallback, you can use "cvs diff" to extract the changes as a
patch, then manually apply it to the branch.
I have tried this in
macosx/app/
and then run 'diff -ru ...' on it against HEAD. They are not identical.
macosx/app/
If I do:
cd /usr/local/src/grass/cvs # HEAD
cvs update
cd /usr/local/src/grass/6.3 # releasebranch_6_3
cvs update
cd macosx/app
cvs update -j HEAD
diff -rq {6.3,cvs}/macosx/app
the only differences are in the CVS/* files (Tag and Entries).
It may be worth updating the directories with "cvs update -A" and
"cvs update -r releasebranch_6_3" respectively to ensure that you
don't have any incorrect sticky tags.
Good point. And probably I just had lagging behind my local HEAD
copy. I'll double check and try again.
