[GRASS-dev] 6.4.0 blocker bugs
Greetings from remote parts of China.
I agree with all about releasing 6.4.
As it stands now 6.4 is much more stable and usable than 6.2.3. wxnviz and wxdigit are experimental for this release, so we shouldn't worry about them too much. The TclTk versions of both work well.
1+ for release as quickly as possible.
Michael
____________________
C. Michael Barton
Arizona State University
voice: 480-965-6262 (SHESC), 480-727-9746 (CSDC)
fax: 480-965-7671 (SHESC), 480-727-0709 (CSDC)
www: www.public.asu.edu/~cmbarton, http://csdc.asu.edu
On Jul 6, 2010, at 10:34 AM, grass-dev-request@lists.osgeo.org wrote:
Date: Mon, 5 Jul 2010 22:34:23 -0400
Subject: Re: [GRASS-dev] 6.4.0 blocker bugs
To: Glynn Clements <glynn@gclements.plus.com>
Cc: Markus Metz <markus.metz.giswork@googlemail.com>, Martin Landa
      <landa.martin@gmail.com>, GRASS developers list
      <grass-dev@lists.osgeo.org>
Message-ID: <BBA240B3-11DC-40AB-B670-D58A8063E478@unity.ncsu.edu>
Content-Type: text/plain; charset=us-ascii
On Jul 5, 2010, at 5:11 PM, Glynn Clements wrote:
Markus Neteler wrote:
time to get out 6.4.0final :slight_smile:
Please...
one huge +1 ...
I learned that we should await the ctypes port to get rid of SWIG?
SWIG is only used within GRASS for the wxGUI vdigit and nviz modules.
It's also used to generate wrappers for programmers who wish to access
the libraries directly, but these aren't used by any part of GRASS.
I suggest disabling all of this in the final release. The vdigit and
nviz modules don't work on Windows, and aren't particularly robust on
other platforms (and being loaded in-process means that any problems
affect the GUI as a whole, not just the vdigit/nviz modules).
Glynn,
I assume you are talking about wxnviz here, not the TclTk based nviz
which runs on windows just fine?
I agree that it is really important to get 6.4 final released, especially given
that FOSS4G in Barcelona is coming soon
Helena
The SWIG wrappers for the libraries are barely usable and are planned
to be replaced, so we shouldn't be encouraging their use.
IOW:
1. The "swig" directory should be removed from DIRS in the top-level
Makefile, so it isn't built (unless the user builds it manually).
2. Official binaries shouldn't use --with-python; this will prevent
the vdigit and nviz modules from being built.
3. Optionally back-port the ctypes wrappers (lib/python/ctypes). Even
if this doesn't work (fails to build or generates broken wrappers), it
shouldn't break anything which would otherwise work.
4. Optionally back-port the ctypes-based nviz module (wxnviz.py). This
has most of the same issues as nviz/vdigit (i.e. the GRASS libraries
are being accessed directly from the GUI process, so a segfault or
G_fatal_error() will kill the GUI), but not all of them.
4b. Alternatively, back-port the changes but not wxnviz.py itself. The
result is equivalent to just building --without-python (i.e. the GUI
will try to import the wxnviz module, fail, and warn that it's
disabled), except that the user can drop in wxnviz.py from SVN if they
want to try it out.
grass-dev mailing list
grass-dev Info Page
