[GRASS-dev] 6.4.0 never-ending story
On Jan 5, 2010, at 6:17 AM, grass-dev-request@lists.osgeo.org wrote:
I just wonder about bugs which are marked as blockers for some months.
Custom Query – GRASS GIS
If nobody is going to fixed them they cannot be marked as blockers.
Then reporter should find someone to fix them, at the end the rc-stage
takes one year...
A big blocker was fixed yesterday - v.delauany broken on Mac and Windows.
Another one - v.digit broken on Windows - seems about to be fixed.
I see:
A) winGRASS related:
* 580 WinGRASS: $GISBASE/etc/gui/scripts/ require something like $(EXE) to run
-> status unclear to me
I'm not sure about this either. Basically, there is a problem running scripts from anything other than the scripts directory. But I hear from the list that this has been fixed in at least some cases. Need someone with Windows to test.
* 759 r.patch non-functional in WinGRASS 6.4 svn on Vista
-> awaiting guru comment
This is due to security routines on *some* Vista systems. It affects more than r.patch and can be capricious, affecting some systems and not others. The workaround is simply to turn off a form of the highest level of security in Vista. Someone who knows Windows could simply add that to the man page for r.patch.
* 809 v.db.addtable consistently fails in winGrass
-> apparently not reproducable?
This is caused by the scripting issues above IIRC. Several of the db modules are scripts. These had problems if they called another script. I don't know if this is or is not a problem. Need someone with Windows to test.
* 843 v.digit broken on new WinGrass release
-> contains a suggestion
In process of being fixed (message today from Hamish)
B) Misc
* 72 PNG driver: boundary rendering is off by one pixel
IMHO not a blocker. This affects visual output but not analytical capabilities. Also only noticeable in special circumstances.
* 384 wxGUI: vdigit crashes on a big map
-> who can confirm?
Should not be a blocker for 6.4 as the TclTk interface is still the official one at this level.
* 461 v.to.db crashes on a shapefile connected with v.external
-> still valid?
Don't know.
Maybe Colin, Helmut, or someone else with Window and an up-to-date Wingrass can quickly run a test to see if any/all are still valid problems. Maybe that can eliminate some.
I personally vote for going ahead and publishing this week RC6
and after 1-2 weeks (really) the final version. A lot of patches
should go into 6.4.1 then which are already piling up.
If this is the list, it seems to me that we are about ready to release.
Michael
I see:
I still experience:
standalone-installer: execution failed on g.proj.exe -p
http://trac.osgeo.org/grass/ticket/827
