[GRASS-dev] 6.4.0svn compilation error with undefined reference to `_'
I am trying to compie 6.4.0svn on a Centos Linux system but have this strange
undefined reference to `_' problem:
cd d.extend/
make
/private/software/grass-6.4.svn/dist.x86_64-unknown-linux-gnu/lib/libgrass_vect.so:
collect2: ld returned 1 exit status
make: *** [/private/software/grass-6.4.svn/dist.x86_64-unknown-linux-gnu/bin/d.extend]
Error 1
nm /private/software/grass-6.4.svn/dist.x86_64-unknown-linux-gnu/lib/libgrass_vect.so
| grep ' _'
                 U _
0000000000237250 a _DYNAMIC
00000000002374b8 a _GLOBAL_OFFSET_TABLE_
                 w _Jv_RegisterClasses
Actually, NLS was included in libgrass_vect.so?
In configure, I have set --with-nls=no. Nontheless the error
appears.
any idea?
cd d.extend/
make
Error 1
| grep ' _'
                 U _
appears.
any idea?
lib/vector/Vlib/rewind.c uses _() so it needs:
  #include <grass/glocale.h>
This should have caused an "implicit function declaration" warning.
