[GRASS-dev] 6.4 Nviz Windows problems
I had a problem compiling nviz from the 6.4 release branch on Windows, with unrecognised Tcl/Tk symbols. Reverting r32244 to put the Tcl/Tk library flags in among the other library linking flags seems to fix it:
http://trac.osgeo.org/grass/changeset/32244
I haven't committed as I don't understand the reason for that change.
Trying to run nviz brings up a further error - see attached - unfortunately no time to look into it further now.
Paul
(attachments)
$(XTRA_LDFLAGS) definitely should go after $(ARCH_OBJS) and
$(SURFLIB). Otherwise, it won't work if either the Tcl/Tk or OpenGL
libraries are static libraries.
I can't reproduce this. Does the file appear to be valid?
On Mon, Dec 22, 2008 at 4:44 AM, Glynn Clements
Attempt to fix in
r34993 (6.4.svn) and
34994 (6.4.0svn)
Yes, I was using static Tcl/Tk. Markus has fixed this now and I can confirm the fix works.
No - it's not there actually. Didn't take much further looking into... the culprit seems to be r32173:
http://trac.osgeo.org/grass/changeset/32173
(-L option added to find command-line). The Msys find doesn't seem to have the -L option - but perhaps it is just a version issue? find --version reports:
GNU find version 4.1
Paul
reports:
FWIW, -L is POSIX:
  http://www.opengroup.org/onlinepubs/009695399/utilities/find.html
It may be that MSys dropped the option due to Windows not having
symlinks, although silently ignoring it would have been better.
7.0 uses $(wildcard ...) instead of "find". That could be used, or
alternatively:
ifneq ($(strip $(MINGW)),)
  FIND = find
else
  FIND = find -L
endif
reports:
FWIW, -L is POSIX:
alternatively:
  FIND = find
else
  FIND = find -L
endif
I've committed the second solution and this is fixed now.
No other pressing problems for 6.4.0 on Windows as far as I can see.
Paul
