Moritz Lennert wrote:
Working with 6.4rc5 compiled as deb
packages on Ubuntu Intrepid, many of
my students had trouble with the map display in the wxgui,
today. I've not
been able to reproduce it systematically, yet, and so am
hesitant to file
this as a bug, but would like to know if others have seen
something similar.
Sometimes, the map display does not seem to refresh
properly. Symptoms can be:
- zooming in the display shows you the new zoomed map, but
also the same map in the previous zoom state.
are the stale map layers actually a decorations? (grid, scalebar,
thematic layer, etc)
- adding a new layer does not make this layer appear in the
map display
hit the redraw button or tick the " always Render" box on the bottom
right of the map display window?
H
Sorry, apparently I was not clear enough:
On Thu, July 2, 2009 09:44, Hamish wrote:
Moritz wrote:
- changing colors or other display parameters does not change the
appearance of the map, even after a full redraw of all maps
in this case r.colors modifies a support file for the map but the GUI
has no way of knowing that has happened. each render-layer in the map
display is cached separately and only recomposed if the GUI knows
that something has changed. finally all render-layers are sandwiched
with appropriate transparency into the image you see in the map display.
I know about the redraw, but this isn't the issue (actually we were
working with vectors where this is not a problem). Even a redraw does not
change the display.
No, it is the actual (in this case vector) map.
map display
All of this has no effect. As mentioned, I have to save the workspace
file, close the workspace and reload the workspace to get correct display.
This has just bitten me again, but still not way of predicting when this
might happen...
Moritz
