FWIW, I haven't been able to compile GRASS 7 from source for many weeks now. Last time I asked William Kyngesburye about it, he had not been able to compile it either. Has anyone else tried on the Mac recently? I get a lot of errors. I am using geos, with a path set to one William's framwork build of geos.
Michael
On Jul 19, 2009, at 8:57 PM, grass-dev-request@lists.osgeo.org wrote:
Date: Mon, 20 Jul 2009 04:57:45 +0100
Subject: Re: [GRASS-dev] 7.svn fails to build from source
To: Hamish <hamish_b@yahoo.com>
Cc: grass-dev <grass-dev@lists.osgeo.org>
Message-ID: <19043.60217.750211.46445@cerise.gclements.plus.com>
Content-Type: text/plain; charset=us-asciiHamish wrote:
Debian/Lenny on 64bit:
many/most modules fail to build with:
main.c:45: undefined reference to `G_add_keyword'it seems to be there in gisdefs.h ..... ??
Defined in lib/gis/parser.c. This suggests that it's linking against
an old version of the library.Debian/Etch on 32bit:
lib/vector/diglib fails with:gcc -I/usr/local/src/grass/svn/trunk/dist.i686-pc-linux-gnu/include -I/usr/local/src/grass/svn/trunk/dist.i686-pc-linux-gnu/include -ggdb -march=pentium4 -Wall -Werror-implicit-function-declaration -fPIC -I/usr/include/gdal -I/usr/include -DPACKAGE=\""grasslibs"\" -I/usr/local/src/grass/svn/trunk/dist.i686-pc-linux-gnu/include -I/usr/local/src/grass/svn/trunk/dist.i686-pc-linux-gnu/include -o OBJ.i686-pc-linux-gnu/allocation.o -c allocation.c
In file included from allocation.c:21:
/usr/local/src/grass/svn/trunk/dist.i686-pc-linux-gnu/include/grass/vector.h:474: error: expected '=', ',', ';', 'asm' or '__attribute__' before '*' tokenDon't use --with-geos.
