[GRASS-dev] a better console and better diff
First, thanks to all who advised me on making a diff that actually patches correctly (I hope).
Here is a console with full autocomplete and calltips. For GRASS 6.5
I've put it on auto to show how it can work, but the autocompletion could move to control key combinations too.
--Type a grass command. When you get to the ".", it brings up an autocomplete list of relevant commands. Keep typing (or mouse up/down) until you find the one you want and hit return.
--Press <tab> to see full calltips of command syntax for each command entered (one command per line please)
--As you type the command arguments, hitting "=" and "," following an "=[string]" combination will bring up context-sensitive lists of relevant maps or other data sets (e.g. regions where appropriate).
--You can type ctrl-space to bring up a context sensitive list of maps for raster, vector, etc. at any place in the command.
--Pressing return on the command line will run it.
This will accept shell commands (redirects and pipes don't work but could), grass commands without arguments (brings up the GUI dialogs), and grass commands with the short form arguments (r.info mymap) as well as full grass commands with argument=value format.
****IMPORTANT WARNING***** Turn OFF the preferences/configuration for default raster color tables. This is causing a bug to affect any command entered from this console or the existing command prompt.
(attachments)
console_example4.patch (15.3 KB)
goutput.py (42.8 KB)
wxgui.py (62.1 KB)
A quick note. I forgot to mention that there is also command history as before. Press ctrl-up or ctrl-down.
Michael
____________________
C. Michael Barton
Arizona State University
Phone: 480-965-6262
Fax: 480-965-7671
www: www.public.asu.edu/~cmbarton, http://csdc.asu.edu
<console_example4.patch><ATT00001.txt><goutput.py><wxgui.py><ATT00002.txt>
For those that ask, here is a set of screenshots showing using the proposed terminal to enter a simple grass command. Hard to capture the actual action, but perhaps this series 1-4 conveys it.
http://www.public.asu.edu/~cmbarton/files/grass_screenshots/console1.jpg
http://www.public.asu.edu/~cmbarton/files/grass_screenshots/console2.jpg
http://www.public.asu.edu/~cmbarton/files/grass_screenshots/console3.jpg
http://www.public.asu.edu/~cmbarton/files/grass_screenshots/console4.jpg
Michael
Michael
C. Michael Barton
Phone: 480-965-6262
Fax: 480-965-7671
console_example4
Michael
Great.
Will this go into the offical code?
Michael
> Michael
> C. Michael Barton
> Phone: 480-965-6262
> Fax: 480-965-7671
>> down)
>> maps
>> console_example4
Hi Michael,
I applied the patch, and it almost works. After running a command, I am not
presented with a new line-- I need to erase the last command in order to
enter a new one.
Also, there is about a 45 second delay between a d.rast command and output on
the canvas... Do you know what could be causing this?
Finally, after about 30 seconds I received a warning that d.erase wasn't yet
supported.
I like the idea here, but the speed of rendering is far too slow for standard
usage.
Dylan
Dylan Beaudette
Soil Resource Laboratory
http://casoilresource.lawr.ucdavis.edu/
University of California at Davis
530.754.7341
Hi Dylan,
Thanks very much for trying this out. A few responses below.
On Dec 15, 2009, at 12:07 PM, Dylan Beaudette wrote:
Hi Michael,
enter a new one.
This seemed weird so I tried it out. This only happens with d.* commands. I don't know why, but am sure that it is fixable.
Mine shows up in a second or two. I'm not sure what is causing this but can speculate a little. First, have you turned on the 'constrain display resolution to computational region settings' in the preferences? If so, and if you have a map with a lot of cells, this will render slowly because d.rast has to write out a file with that many pixels, then on the fly compress them into the size that fits into your screen window. This would be the case with any image renderer. The default is to turn this off and have intelligent rendering, where the graphic file rendered by d.rast is sized to match the display window in advance. So it writes comparatively few pixels. For most purposes, GRASS should stay in this mode because you can only see the number of pixels in your display window, regardless of the number of cells in your map.
If you do not have the 'constrain display resolution..' mode set this way, I'm don't know what the problem is. Even very large maps display quite quickly for me--in a couple seconds at the most. Could be you are out of disk space or RAM???
supported.
This may be related to the slow rendering issue. I get the message that d.erase is not implemented immediately. Note that d.erase should be easy to implement.
usage.
Clearly this is far too slow, but the rendering speed (or rather its lack) is not a function of either the console or wxPython canvas in this case. Is it that slow when you display from the layer manager too?
Have you tried it for other commands -- all the non display commands? Other shell commands? Any thoughts?
Michael
On Tuesday 15 December 2009, Michael Barton wrote:
Hi Dylan,
> Hi Michael,
> not presented with a new line-- I need to erase the last command in order
> to enter a new one.
OK. I'll wait and see how things develop with the d.* commands. Overall, I
really like the idea, and command-completion is a real time saver!
> output on the canvas... Do you know what could be causing this?
I checked, and the 'constrain display resolution to computational region
settings' box was un-checked. I am working with the default Spearfish region,
so this really isn't all that many cells.
3Gb RAM and 2x XEON processors here, shouldn't be bottleneck there...
> yet supported.
implement.
> standard usage.
All commands seem to have a delay-- even executing g.region causes the CPU to
jump to 100% for about 15 seconds.
Dylan
Michael
Dylan Beaudette
530.754.7341
What is your OS?
Something is very squirrelly. I'm also looking at spearfish. All displays should be in a second or two; commands like r.info should be instantaneous. I'm on a MacBook with 2Gb RAM and a 2.4 GHz core duo. So it's not as hot as your machine.
Do you have any other strange issues/messages with the GUI or Python?
Michael
C. Michael Barton
Phone: 480-965-6262
Fax: 480-965-7671
Hi Dylan,
Hi Michael,
to enter a new one.
yet supported.
implement.
standard usage.
Dylan
Michael
Dylan Beaudette
530.754.7341
What is your OS?
your machine.
Michael
No obvious issues, however the GUI does take about 20 seconds to load. OS is
Debian/Unstable.
Here is the version info of the wx-related stuff:
libwxbase2.8-0 2.8.7.1-2+b1
python-wxgtk2.8 2.8.7.1-2+b1
wx2.8-headers 2.8.7.1-2+b1
Dylan
Phone: 480-965-6262
Fax: 480-965-7671
>> Hi Dylan,
>>> Hi Michael,
>>> order to enter a new one.
> Hi,
> I really like the idea, and command-completion is a real time saver!
> region, so this really isn't all that many cells.
>>> wasn't yet supported.
>> to implement.
>>> standard usage.
> CPU to jump to 100% for about 15 seconds.
> Cheers,
> Dylan
>> Michael
> Dylan Beaudette
> 530.754.7341
Dylan Beaudette
530.754.7341
causes the CPU to jump to 100% for about 15 seconds.
time enough to run `top` and see what's the hog..
H
If d.erase were implemented in the GUI console, how should it work?
1) remove all maps and other displays from the layer tree
2) turn off all maps and other displays from the layer tree
#1 is what it did in an xmon, but that may not be the desired behavior in the current environment.
Michael
C. Michael Barton
Phone: 480-965-6262
Fax: 480-965-7671
H
2009/12/11 Michael Barton <michael.barton@asu.edu>:
Most of the things are already implemented in GPrompt! Better would be
to make working GPrompt class on Mac.
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
On Dec 16, 2009, at 4:22 AM, Martin Landa wrote:
Martin
Hi Martin,
GPrompt won't work on the Mac because it uses a the PopupWindow control that does not exist for Mac. To make it work, it would be necessary to custom code an equivalent popup window.
If we use the separate command entry window interface, I think the better way to go is to change it to a StyledTextCtrl. This was a very good idea of yours to make the output window a StyledTextCtrl.
If the input window is changed to a STC, then we can make use of its built-in autocomplete and calltip functions. I realize that you did a lot of coding to create a custom autocomplete in GPrompt, but I think we are ultimately better off to use wxPython built-in functions as much as possible when they are available. They are often more robust over time and easier for another person to understand--and others than you and I may well need to debug and maintain this in the future. I've seen a lot of old custom widget code for the TclTk GUI and it is very difficult to deal with. If we create a custom popup that works on Mac, we add even more custom code for an autocomplete feature.
In this case, the STC autocomplete and calltip functions work very well and we only need to create the relevant lists of informatoin (commands, maps, etc) that go into them and the specify the keystrokes that call them. I've done that and we can make use of and enhance that code (e.g., change the keystrokes if desired). We don't need to code list controls, the ability to type and search, popup windows, getting the list into the popup, and the proper placement of the windows.
I personally don't mind separate input and output windows. Many people who use terminals are accustomed to having input and output in the same window, and using the STC, it is minimal effort to have this kind of interface. But maybe command line users like the idea of separate input and output windows. We probably can also visually merge the 2 windows so that the input acts more like a command line prompt that never scrolls up. I guess I'd recommend whichever way terminal users are most comfortable with in this regard.
Michael
d.erase still exists, and works with direct rendering. The result a
blank image.
This may not be a great deal of use within the GUI, but it does work.
It is useful in other contexts (e.g. creating the initial image if you
intend to use GRASS_PNG_READ=TRUE for subsequent commands).
2009/12/16 Michael Barton <Michael.Barton@asu.edu>:
right, this what I was suggesting from the beginning. Feel free to
implement GPromptSTC. My personal meaning is that most of GUIs use
different widgets for input area (when you type commands) and log
area.
Martin
On Wednesday 16 December 2009, Michael Barton wrote:
Darn. All of my ideas about why this doesn't work right don't work. I guess
try what Hamish said.
Michael
OK--
This time, starting GRASS, and the GUI-- and raster and vector maps are
displayed within about 2-6 seconds. I wonder if this is a byte-code compiling
thing... the first time GRASS was run with the new modules = slow, closing
and opening again = fast?
looking at the output in top, I could see that a process called 'python' was
using 99% of CPU, and about 3% of available memory. Nothing else looked
suspicious.
I really like the auto-complete stuff, with a little work this may be a
workable alternative to the X11-based monitor. It is still about 2-3x slower
than the X11 version. Is the GUI faster on GRASS 7?
Thanks for all of the hard work!
Dylan
______________________________
C. Michael Barton
Tempe, AZ 85287-2402
USA
voice: 480-965-6262; fax: 480-965-7671
www: http://csdc.asu.edu, http://shesc.asu.edu
>> Do you have Python 2.5? Other version?
>> Michael
> using python 2.5
> Dylan
>> C. Michael Barton
>> USA
>>>> What is your OS?
>>>> Michael
>>> Hi,
>>> OS is Debian/Unstable.
>>> Cheers,
>>> Dylan
>>>> Phone: 480-965-6262
>>>> Fax: 480-965-7671
>>>>>> Hi Dylan,
>>>>>>> Hi Michael,
>>>>>>> I am not presented with a new line-- I need to erase the last
>>>>>>> command in order to enter a new one.
>>>>> Hi,
>>>>> Overall, I really like the idea, and command-completion is a real
>>>>> time saver!
>>>>> region settings' box was un-checked. I am working with the default
>>>>> Spearfish region, so this really isn't all that many cells.
>>>>>>> for standard usage.
>>>>>> too?
>>>>> Cheers,
>>>>> Dylan
>>>>>> Michael
I think that separate windows make more sense, but it's worth allowing
the input window to be a multi-line field with line-wrap and vertical
scrolling, rather than a single-line field with horizontal scrolling.
The latter can be annoying when entering long commands.
This makes some sense.
Python compiles at runtime. So the first time you run the GUI, each module will compile the first time it is run. Subsequently, all modules will run the compiled code. If you update and the code in a compiled and uncompiled module do not match, that module will compile the first time you use it again.
Michael
C. Michael Barton
USA
Michael
OK--
suspicious.
Dylan
C. Michael Barton
USA
Michael
using python 2.5
Dylan
C. Michael Barton
USA
What is your OS?
Michael
Dylan
Phone: 480-965-6262
Fax: 480-965-7671
Hi Dylan,
Hi Michael,
time saver!
for standard usage.
too?
Dylan
Michael
2009/12/16 Glynn Clements <glynn@gclements.plus.com>:
I agree, GPrompt should be improved in this way...
Martin
2009/12/16 Martin Landa <landa.martin@gmail.com>:
sorry do you mean separate windows or widgets (in the sense of SDI)?
Martin
