There has been a thread about how v.transform functions and Glynn pointed
out that part of the problem is that the short description does not really
describe what it does, at least from a GIS perspective:
" Transforms a vector map layer from one coordinate system into another
coordinate system."
I'm working on wxgrass menus at the moment and trying to come up with useful
menu entries. A better short description for v.transform might be:
"Reposition (shift and rotate) vector file in coordinate space"
Thoughts?
Michael
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
v.transform: perform affine transformation (translate and rotate) a
vector file.
See affine transformation in wikipedia.
John
Indeed. I recently did some stuff with v.transform / affine transformation.
perhaps I can summarize it, and include a helpful figure in the man page.
http://casoilresource.lawr.ucdavis.edu/drupal/node/433
specifically the shifted grid example:
http://casoilresource.lawr.ucdavis.edu/drupal/node/435
cheers,
vector file.
John
grass-dev mailing list
grass-dev@grass.itc.it
Dylan Beaudette
Soils and Biogeochemistry Graduate Group
University of California at Davis
530.754.7341
coordinate system."
Thoughts?
It can also scale.
> really describe what it does, at least from a GIS perspective:
> coordinate system."
> useful menu entries. A better short description for v.transform might be:
> Thoughts?
It can also scale.
... and to be complete, it can also shear.
Dylan Beaudette
530.754.7341
> > coordinate system."
> > Thoughts?
> It can also scale.
Only when using the pointsfile= option; there isn't any direct way to
specify a transformation which includes shear.
> > > coordinate system."
> > > Thoughts?
> > It can also scale.
Yes, good (point) . It would be an interesting add-on, to manually
specify the components of the affine transformation matrix. perhaps in
addition to the existing manual adjustments. Maybe I will have a try
at this.
cheers,
dylan
vector file.
John
I have update the one line description of the module. It would be good
to get the description.html extended, too.
View this message in context: http://www.nabble.com/a-suggestion-for-v.transform-tf3919605.html#a11273342
Sent from the Grass - Dev mailing list archive at Nabble.com.
