I'm trying to convert a segment map into a vector map, I'm using GRASS7 (r58321), but I got:
G70> r.to.vect --o --v input=seg_0.05_final@pietro output=seg005 type=area
WARNING: Vector map <seg005> already exists and will be overwritten
Using native format
Extracting areas...
100%
Writing areas...
100%
Building topology for vector map <seg005@pietro>...
Registering primitives...
Unexpected error.
Aborted (core dumped)
G70> v.info map=seg005
WARNING: Coor file of vector map <seg005@pietro> is larger than it should
be (3198718980 bytes excess)
| Mapset: pietro |
| Database: /home/pietro |
| Title: |
| Map scale: 1:1 |
| Name of creator: pietro |
| Organization: |
| Source date: Thu Nov 28 20:55:18 2013 |
| Timestamp (first layer): none |
| Map format: native |
| Type of map: vector (level: 1) |
| Number of points: 0 Number of centroids: 5970928 |
| Number of lines: 0 Number of boundaries: 16325866 |
| Number of areas: 0 Number of islands: 0 |
| Map is 3D: No |
| Number of dblinks: 1 |
| Projection: UTM (zone invalid) |
| N: 7104206.80119541 S: 7089186.6842956 |
| E: 759827.4950082 W: 745280.94984459 |
| Digitization threshold: 0 |
| Comment: |
the problem raise when I try to build the topography, running v.build I got:
G70> v.build map=seg005 --v
22296794 primitives registered
189966723 vertices registered
Building areas...
Unexpected error.
What it is wrong and how to fix it? Any ideas?
Best regards
Pietro
