I have created pull requests for test_module_assertions.py and for updating gunittest.cfg file. Check the pr if any mistake is there. Thank you sir for your support and guidance. With your help I could create the first pull request for osgeo. Should I test other files also in gunittest.cfg for gsoc 2022.
Great. I have left a new round of reviews.
#2311 looks hopeful and #2310 is not necessary, so no further changes are needed in either at this point. Focus on fixing some tests.
