Markus Metz wrote:
>>> Ah, ok, you use the grass57 dataset. I have now changed the version
>>> number and compatibility info, you should now get reasonable
>>> warnings/errors with the spearfish57 dataset.
>> Okay, I'll check it.
> Nope. As of r38644, the error message is unchanged.I got the order of the checks wrong. First check must be version check,
only after that comes the check for file size. That LFS check is there
to check if sizeof(off_t) = 8 is needed to read the sidx file. Fixed in
r36845.
Yep; it now says:
ERROR: Spatial index format version 5.0 is not supported by this release.
Please rebuild topology.
However, as a result of the LFS changes, the code has some type
mismatches on 32-bit systems with LFS enabled.
Most of these are due to passing off_t's to G_debug() with %ld as the
format (it needs to be %lld for a 64-bit off_t on a 32-bit platform;
we really need a macro for this). There's also one G_fatal_error()
call which has "%d".
These shouldn't actually cause any problems beyond reporting bogus
offsets in debug/error messages. On little-endian platforms, the
offset will be truncated to 32 bits (so it has no effect for offsets
<2GiB). It's more of an issue on big-endian platforms, as you get the
high word, so offsets will be divided by 4GiB (i.e.they'll normally be
zero).
In lib/vector/diglib/port_init.c,
#define OFF_T_TEST 0x0102030405060708
should have an LL suffix (it's too large for an "int"), and this
should ideally be conditionalised (although I don't know if we have a
macro for "off_t is 64-bits"; _FILE_OFFSET_BITS may not be defined on
64-bit platforms, and you can't use sizeof in #if tests). I believe
that the compiler is free to truncate the above to an int, regardless
of what it's assigned to. If that happens, the vector code will fail
entirely.
Finally:
spindex_rw.c:657: warning: cast from pointer to integer of different size
spindex_rw.c:715: warning: cast to pointer from integer of different size
spindex_rw.c:746: warning: cast to pointer from integer of different size
The first one is less of an issue; a platform with 64-bit pointers
will probably have a 64-bit off_t. The converse isn't true; on a
32-bit system with LFS, storing a 64-bit off_t in a 32-bit pointer
isn't going to work.
The lines in question are:
656: if (s[top].sn->level == 0) /* leaf node */
657: s[top].pos[j] = (off_t) s[top].sn->branch[j].child;
714: s[top].sn.branch[j].child =
715: (struct Node *)s[top].childpos[j];
745: s[top].sn.branch[j].child =
746: (struct Node *)s[top].childpos[j];
ISTR that it should only cast childpos[j] to a pointer if that is what
was stored there in the first place. But I would strongly suggest
using a union rather than casting; we shouldn't expect people to
simply ignore compiler warnings, and it's unreasonable to expect
anyone to analyse the code to the extent that they can determine that
the warnings are harmless.
