Greetings
I’m working on 6.4.0 version and I want to build a Python scripts that acess multiple files. From GRASS7 i.spectral I see that raster variable is a multiple and this is performed.
raster = options[‘raster’]
rastermaps = raster.split(‘,’)
My question is regarding this: how can I access second file for, for instance, do a mapcalc or a for cycle?
Thank you
Luis
Luis Lisboa wrote:
I'm working on 6.4.0 version and I want to build a Python scripts that acess
raster = options['raster']
rastermaps = raster.split(',')
The .split() method returns a list, so in the above case you can use
e.g.:
for map in rastermaps:
Thanks Glynn. Regarding the split function, is is part of GRASS pythin Scripting Library or from normal Python library?
And how can I access an item from the rastermaps list? using rastermaps[0] and rastermaps[1]?
Thank you
On Wed, Feb 17, 2010 at 7:12 PM, Glynn Clements <glynn@gclements.plus.com> wrote:
e.g.:
It's part of Python (it's a method of Python's string class).
and rastermaps[1]?
That will work; however, if you need to iterate over a list, use:
for x in list:
or if you need the indices as well as the items:
for i, x in enumerate(list):
Avoid using C-style iteration, i.e.:
for i in xrange(len(list)):
x = list[i]
Operations on Python's sequence types (including strings and lists)
are documented at:
http://docs.python.org/library/stdtypes.html#sequence-types-str-unicode-list-tuple-buffer-xrange
There's a Python tutorial at:
http://docs.python.org/tutorial/
Also, refer to the existing Python scripts in GRASS 7 for examples:
http://trac.osgeo.org/grass/browser/grass/trunk/scripts
