[GRASS-dev] Access to GRASS GIS addons
Dear QGIS developers,
I'd much appreciate some response in the following questions.
I rarely use Windows, yet I would like to learn about the latest status in
accessing GRASS GIS addons (not only regular modules) through QGIS under
Windows.
If I write an addon for GRASS GIS, can I then provide/ensure access to it for
Windows users of QGIS?
Thank you, Nikos
(Apologies for re-posting; I was not subscribed to the qgis-developer list
before)
Windows.
The are related documentations:
- https://docs.qgis.org/testing/en/docs/user_manual/grass_integration/grass_integration.html?highlight=grass#customizing-the-grass-toolbox
- https://qgis.org/en/site/getinvolved/development/addinggrasstools.html
Are these up-to-date?
Thank you, Nikos
Dear Nikos,
Approaches are a bit different for Processing and the GRASS plugin, though both do not allow usage of GRASS addons out-of-the-box.
Assuming you are aiming at integration in Processing have a look here:
https://gis.stackexchange.com/questions/150100/how-to-add-my-own-grass-algorithms-to-processing
and
https://github.com/qgis/QGIS/blob/b3d2619976a69d7fb67b884492da491dfaba287c/python/plugins/processing/algs/grass7/description/r.horizon.height.txt
on how you would have to tweak local GRASS and QGIS installation.
For less experienced users that are supposed to use the addon, you would probably want to write a little installation routine for your addon, that puts txt files into right places in the installation and also installs the GRASS addon systemwide...
Stefan
-----Original Message-----
From: grass-dev <grass-dev-bounces@lists.osgeo.org> On Behalf Of Nikos Alexandris
Sent: onsdag 10. oktober 2018 17:45
To: qgis-developer@lists.osgeo.org
Cc: grass-dev@lists.osgeo.org
Subject: [GRASS-dev] Access to GRASS GIS addons
I rarely use Windows, yet I would like to learn about the latest status in accessing GRASS GIS addons (not only regular modules) through QGIS under Windows.
If I write an addon for GRASS GIS, can I then provide/ensure access to it for Windows users of QGIS?
Thank you, Nikos
On 11/10/18 07:53, Stefan Blumentrath wrote:
Dear Nikos,
and
Also note that there was a GSoC project to try to implement functionality that would make integration easier:
https://trac.osgeo.org/grass/wiki/GSoC/2018/IntegrationInQGIS3
but this seems to have been terminated early. At least I never saw a final report. Maybe Vaclav can update us on where we are at with this ?
See also the discussions here:
https://lists.osgeo.org/pipermail/grass-dev/2018-February/087353.html
Moritz
On Thu, Oct 11, 2018 at 10:28 AM Moritz Lennert <mlennert@club.worldonline.be> wrote:
Yes, it was terminated between 1st and 2nd evaluation. Code is useful for reference.
A 2016 GSoC project took different approach which could be reused in QGIS independently from the current GRASS Plugin or Processing plugin approaches. This is a good base for future work, perhaps even for auto-generating the files needed for GRASS plugin or Processing plugin.
https://trac.osgeo.org/grass/wiki/GSoC/2016/PyQtGUI
čt 11. 10. 2018 v 17:24 odesílatel Vaclav Petras <wenzeslaus@gmail.com> napsal:
If you start QGIS from the GRASS GIS shell, then you can use a module g.pyqt from the above-mentioned GSoC project and parse the name of the AddOn as a parameter. It will generate the fully-working GUI for you.
So if you want to create a QGIS plugin and don’t want to create the GUI from scratch, then you can call something like g.pyqt r.estimap after clicking on the icon of the plugin and it’s done. However, it will still work just with maps in GRASS, it will not import them into QGIS or something, and there is also this strange thing about running QGIS from the GRASS GIS shell.
And I didn’t touch the code for some time, so there are still some places which should be improved. But it should be working if you have your AddOn installed in GRASS.
PS: I believe that the code can be also re-written to generate the QGIS plugin GUI without all those strange necessities without so much work, but unfortunately I don’t have enough time to do it in the near future.
Ondrej, thanks for the update. You can consider creating tickets on GitHub with your ideas/future directions of development and you could put there “help wanted” label to make it clear that there are plans for the project.
* Ondřej Pešek <pesej.ondrek@gmail.com> [2018-10-11 20:20:40 +0200]:
napsal:
So if you want to create a QGIS plugin and don't want to create the GUI
from scratch, then you can call something like `g.pyqt r.estimap` after
clicking on the icon of the plugin and it's done. However, it will still
GRASS GIS shell.
And I didn't touch the code for some time, so there are still some places
installed in GRASS.
unfortunately I don't have enough time to do it in the near future.
Thank you Ondřej, also through the list.
(@all: we are not far away with Ondřej these days and he already helped me,
i.e. took time earlier in August and explained how it works under Linux, and
during the last days we did make it work on-site--I am yet to try it on a
Windows box though.)
However, I try to collect as much information as I can about it in order to
find the best solution for Windows users. And I think it is a question
that is of interest for all of us, users of GRASS GIS and QGIS,
regardless of the OS.
Following options:
1. PyQTGUI
- Works under Linux for QGIS 2.x,
- Requires softlinking the Addon's directory which should reside inside
  the PyQTGUI (and possible named without a dot) to QGIS' plugins
  directory -- I guess this can be scripted
- Would require to ship the Addon with the complete PyQTGUI
- Yet to test under Windows
2. PyQGIS?
3. QGIS GRASS Plugin
4. QGIS Processing -- see also: https://gis.stackexchange.com/a/223770/5256
5. Ondřej suggested also another possibility: if an Addon is installed, maybe
then, inside QGIS: GRASS GIS Plugin > GRASS GIS shell > run `r.<addon> --ui`
would suffice?
Any Windows user possibly to try this last option?
Note, there is an "answer" by @Vaclav at
https://gis.stackexchange.com/a/173536/5256, which is rather
discouraging for GRASS GIS Addons through QGIS. I hope we can update it.
Nikos
5. Ondřej suggested also another possibility: if an Addon is >installed,
maybe
then, inside QGIS: GRASS GIS Plugin > GRASS GIS shell > run `r.><addon>
--ui`
would suffice?
What is a GRASS GIS shell within the QGIS GRASS plugin?
best regards
Helmut
Sent from: http://osgeo-org.1560.x6.nabble.com/Grass-Dev-f3991897.html
I think QGIS GRASS Plugin is something different; it's not about using GRASS
modules/addons in QGIS
best regards
Helmut
Dear Nikos and others,
First of all, we have to clarify if you:
a) want a solution that does not require a GRASS database (meaning a Processing like approach) or
b) if an existing GRASS database is acceptable as a requirement to run your addon
If the answer is a), the Situation (in QGIS 3) regarding GRASS integration in QGIS is indeed far from ideal.
In order to change that, a bigger effort seems necessary (as envisioned in the GSoC).
As a workaround for a) you could write a Processing Python script as a wrapper that uses the grass --exec functionality with a temporary GRASS DB and:
1) installs the addon if it does not exist
2) takes QGIS layers (and additional parameters) as input, imports the layers to the temporary GRASS DB, runs your addon and exports the results
The QGIS-GRASS-plugin seems to work also in QGIS 3. It is fully possible to get addons into the GRASS-plugin. Yet, same as for processing, you have to manipulate the installation (which probably not all users would be allowed and able to do).
In any case, with current solutions you will have to recreate the UI in QGIS.
Stefan
Sent: fredag 12. oktober 2018 02:31
To: Ondřej Pešek <pesej.ondrek@gmail.com>
Cc: GRASS developers list <grass-dev@lists.osgeo.org>
Subject: Re: [GRASS-dev] Access to GRASS GIS addons
napsal:
but unfortunately I don't have enough time to do it in the near future.
(@all: we are not far away with Ondřej these days and he already helped me, i.e. took time earlier in August and explained how it works under Linux, and during the last days we did make it work on-site--I am yet to try it on a Windows box though.)
However, I try to collect as much information as I can about it in order to find the best solution for Windows users. And I think it is a question that is of interest for all of us, users of GRASS GIS and QGIS, regardless of the OS.
Following options:
1. PyQTGUI
2. PyQGIS?
5. Ondřej suggested also another possibility: if an Addon is installed, maybe then, inside QGIS: GRASS GIS Plugin > GRASS GIS shell > run `r.<addon> --ui` would suffice?
Note, there is an "answer" by @Vaclav at https://gis.stackexchange.com/a/173536/5256, which is rather discouraging for GRASS GIS Addons through QGIS. I hope we can update it.
Nikos
* Helmut Kudrnovsky <hellik@web.de> [2018-10-12 01:18:37 -0700]:
maybe
--ui`
would suffice?
Helmut,
assuming all QGIS and GRASS-GIS things are installed properly (testing
now with 2.18),
- Plugins > Manage and Install Plugins... > GRASS 7
- Once installed/enabled, select a GRASS GIS Location/Mapset
directory in the Browser Panel
- Click on the "GRASS Tools" icon/button or achieve the same via
Plugins > GRASS > Open GRASS Tools
- First available option under GRASS MODULES is the 'GRASS shell'.
There, it is possible to do something like `g.region --ui`.
N
* Helmut Kudrnovsky <hellik@web.de> [2018-10-12 01:26:00 -0700]:
I think it is possible to make a(ny) GRASS module available to it,
as it is mentioned at
https://docs.qgis.org/2.18/en/docs/user_manual/grass_integration/grass_integration.html#customizing-the-grass-toolbox.
I have not done yet so. There is a further link there, cannot access its
content however.
Nikos
* Stefan Blumentrath <Stefan.Blumentrath@nina.no> [2018-10-12 09:00:07 +0000]:
First of all, we have to clarify if you: a) want a solution that does
not require a GRASS database (meaning a Processing like approach) or b)
your addon
integration in QGIS is indeed far from ideal. In order to change that,
DB and: 1) installs the addon if it does not exist 2) takes QGIS layers
QGIS.
Stefan,
what I seek for is easier than a).
- GRASS GIS has to be installed
- GRASS GIS data base will be the one to work with
- QGIS 2.18, which it LTR, is the preferred version
I think the "Processing" approach is a good one since it requires
minimal scripting/translation and copying of some files in the right
places.
Else, the PyQTGUI approach might also be good despite the fact that we
have to find a way to ship it together with an add-on. It will work with
a script to execute that creates the required soft-link(s) and some
clicks to activate it as an independent "Experimental" addon.
Now,
there is this weird situation now where I cannot install the add-on module I
wrote under Windows using `g.extension`. The module is not published in
the official repository (and I have to get a permission before I do so).
The current framework does not support compiling from source.
So, it's difficulty to proceed in testing anything.
How do we compile and package a single GRASS GIS Addon binary to proceed
with testing under Windows?
Nikos
How do we compile and package a single GRASS GIS Addon >binary to proceed
see
https://wingrass.fsv.cvut.cz/grass77/x86_64/addons/grass-7.7.svn/
for the precompiled wingrass addons.
have a look into one of the zip File how the structure looks like.
best regards
Helmut
* Helmut Kudrnovsky <hellik@web.de> [2018-10-12 12:25:47 -0700]:
see
Thank you Helmut.
(@Martin) Is the process that generates these "pre-compiled" addons accessible?
Nikos
Here a working solution (as explained/provided by Stefan) for the
"Processing Toolbox". Note, below "grass-ltr" maybe any grass 7.x
version, like grass-7.4.svn
1. Copy a GRASS GIS addon, say `r.example` under
C:\OSGeo4W64\apps\grass\grass-ltr\scripts\
2. Copy a Windows Batch file named after the addon, of course with the
extension of the file being `.bat` under
C:\OSGeo4W64\apps\grass\grass-7.4.svn\bin\ # r.estimap.bat
whose content should be:
@"%GRASS_PYTHON%" "%GISBASE%/scripts/<AddonName>.py" %*
3. For the description of the UI, copy `r.example.txt` under
C:\OSGeo4W64\apps\qgis\python\plugins\processing\algs\grass7\description\
The above steps will make the addon listed under the list of GRASS GIS
algorithms, inside the Processing toolbox.
4. There is another thing (yet to test): perhaps a file name r_example.py
is required under
in C:\OSGeo4W64\apps\qgis\python\plugins\processing\algs\grass7\ext
Looking at existing files there-in, they are not the "same" and I guess
it's going to be required (to understand what and how) in order to get
an addon running as expected.
Nikos
