I’m trying to access a grass vector map with python (2.6). I’m using the svn version (revision 42 565) but keep getting “Segmentation fault” when trying to open the file with Vect_open_old (map, input, mpaset). The code I’m using can be found here: http://osgeo.pastebin.com/VLGunxyq
Can you please tell me I’m doing wrong (the same code works well with python libraries generated with SWIG)?. Greetings. Thank you very much.
Ing. Fernando Pacheco M.S.L.
Ingesur srl
Dirección: Requena 1062 ap.302, Montevideo, Uruguay.
Teléfonos: (+598 2) 408 90 48, (+598 9) 962 79 32
Web: http://ingesur.com.uy/
Fernando Pacheco wrote:
I'm trying to access a grass vector map with python (2.6). I'm using the svn
version (revision 42 565) but keep getting "Segmentation fault" when trying
to open the file with Vect_open_old (map, input, mpaset). The code I'm using
Can you please tell me I'm doing wrong (the same code works well with python
There are two problems, one in your code, one in the ctypes wrappers.
First, Vect_open_old needs a pointer to a a Map_info structure, not
the structure itself, so you need to use byref(), e.g.:
from ctypes import *
vector.Vect_open_old(byref(map), input, mapset)
Second, if LFS is enabled, any files which use the vector structures
are compiled with -D_FILE_OFFSET_BITS=64. This wasn't being passed to
the preprocessor when the ctypes wrappers were generated, resulting in
incorrect wrappers being generated for various structures, including
the Map_info structure. This should be fixed by r42566.
Woks!. Thank you. Fernando.
Ingesur srl
On Tue, Jun 15, 2010 at 1:56 PM, Glynn Clements <glynn@gclements.plus.com> wrote:
are compiled with -D_FILE_OFFSET_BITS=64. This wasn’t being passed to
I modified the code as you have suggested. But I encounter a new problem. If I run a simple program from the command line like this: http://osgeo.pastebin.com/pPqkcvk3 get the following error:
“python: malloc.c:4628: _int_malloc: Assertion `(unsigned long)(size) >= (unsigned long)(nb)’ failed.”
I updated the code to the 42566 version but I still have the same problem. Any suggestions?. I will keep trying!. Thank you. Fernando.
Ingesur srl
On Tue, Jun 15, 2010 at 2:10 PM, Fernando Pacheco <fernando.pacheco@ingesur.com.uy> wrote:
Ingesur srl
"python: malloc.c:4628: _int_malloc: Assertion `(unsigned long)(size) >=
(unsigned long)(nb)' failed."
That's the error which I saw before fixing the wrappers.
Did you run "make clean" after updating? Makefiles aren't treated as
prerequisites, so an incremental build won't cause the wrappers to be
regenerated.
It should suffice to run:
make -C lib/python/ctypes clean
Yes of course, after updating the source code to the 42 566 version I ran “make clean”, “./configure …”, “make”, "rm-rf / usr/local/grass-7.0.svn " and “make install”. In this situation is that I get the error mentioned in my previous email.
If you have suggestions or an example that works please send me. I need to make a decision about the language used to develop the application (I want to use Python!). Thank you very much. Greetings. Fernando.
Ingesur srl
On Tue, Jun 15, 2010 at 7:45 PM, Glynn Clements <glynn@gclements.plus.com> wrote:
That’s the error which I saw before fixing the wrappers.
Did you run “make clean” after updating? Makefiles aren’t treated as
prerequisites, so an incremental build won’t cause the wrappers to be
regenerated.
I think there is an error in the generation process with ctypesgen for vector.py. The problem is that “dig_estructs.h” needs the heading “ogr_api.h” which is not found in the path included. The problem is solved if you add the path to that file (in my case -I/usr/include/gdal). Thank you. Greetings. Fernando.
Ingesur srl
On Wed, Jun 16, 2010 at 1:12 AM, Fernando Pacheco <fernando.pacheco@ingesur.com.uy> wrote:
Ingesur srl
regenerated.
vector.py. The problem is that "dig_estructs.h" needs the heading
"ogr_api.h" which is not found in the path included. The problem is solved
Try r42567.
Everything works correctly now, the problem has been fixed.
I think the interface generated automatically with ctypesgen (like that of SWIG) isn’t attractive for inexperienced developers. It works very well and is fast, but the calls to the functions are complex (logically identical to those of C) and is not what an average developer would expect in Python.
In the coming months we will be developing an interface for finite element modeling (Fenics project=Dolfin, Tritetmesh, etc.). We will start by making access to vector layers with Python more friendly, taking as a starting point what has been generated with ctypesgen. Thank you. Greetings. Fernando.
Ingesur srl
On Wed, Jun 16, 2010 at 12:13 PM, Glynn Clements <glynn@gclements.plus.com> wrote:
Try r42567.
SWIG) isn't attractive for inexperienced developers. It works very well and
I don't think that there is a realistic alternative.
If you modify the wrappers, you then have to update the modified
wrappers as the underlying libraries change. I just can't see this
happening.
Realistically, any higher-level interface is going to have to be built
on top of whatever is generated by ctypesgen, not replace it.
I can't see anyone being willing to specifically maintain
hand-generated wrappers, and we aren't likely to impose a requirement
that anyone modifying a header file must manually modify the
associated Python wrapper to match.
In fact, the lowest levels must be auto-generated to allow for
platform-specific details, e.g. the _FILE_OFFSET_BITS issue.
