Hi Markus,
On Mon, Jul 27, 2015 at 4:24 PM, Markus Neteler <neteler@osgeo.org> wrote:
On Mon, Jul 27, 2015 at 1:59 PM, Pietro <peter.zamb@gmail.com> wrote:
ok, I've commited the changes in lib/init/grass.py and in the
lib/python/gunittest/*
Please post to the list how to switch to Python3 in case that multiple
versions are available.
Like this more testers may join.
You are righ, here some instruction to test and find bugs...
You must have python3 installed on your machine, from a terminal
python3 /usr/bin/grass71 -getxt ~/docdat/gis/nc_spm_08_grass7/py34 -c
then start a python interpreter and execute some code
[Note1: this example should not work on your machine since I didn't
commit this part so far;
Note2: GRASS with python3 it is working only in text mode no GUI!]:
$ python3
from grass.script import core as gcore
gcore.gisenv()
{'GISDBASE': '/home/pietro/docdat/gis', 'GUI': 'gtext', 'MAPSET':
'py34', 'LOCATION_NAME': 'nc_spm_08_grass7'}
To check if the result in python2 is the same then open a new terminal
and execute
$ python2 /usr/bin/grass71 -getxt ~/docdat/gis/nc_spm_08_grass7/py27 -c
$ python2
gcore.gisenv()
{u'LOCATION_NAME': unc_spm_08_grass7', u'GISDBASE':
u'/home/pietro/docdat/gis', u'MAPSET': u'py27', u'GUI': u'gtext'}
You can also start executing Vaclav's unittest library, go to a directory:
$ cd lib/python/script
$ python3 -m grass.gunittest.main --location nc_spm_08_grass7 --location-type nc
test_start_command_functions_nc from . failed
test_start_command_functions from . failed
test_doctests from . failed
Executed 3 test files in 0:00:09.962775.
From them 0 files (0%) were successful and 3 files (100%) failed.
$ python2 -m grass.gunittest.main --location nc_spm_08_grass7 --location-type nc
Executed 3 test files in 0:00:10.358305.
From them 3 files (100%) were successful and 0 files (0%) failed.
or execute a specific test file with:
$ python3 testsuite/test_start_command_functions_nc.py
So far the test in the script directory are still failing I'm working
to fix them...
All the best
Pietro
