[GRASS-dev] "add to display" when running module from the SHELL
in the GUI of modules we can select to add to display,
is there (or would there be) a possibility to do the same when running from the CLI/SHELL?
Thank you,
Yann
2017-02-03 9:44 GMT+01:00 Yann Chemin <dr.yann.chemin@gmail.com>:
the CLI/SHELL?
d.mon wx0
d.rast ...
d.vect ...
Ma
Martin Landa
http://geo.fsv.cvut.cz/gwiki/Landa
http://gismentors.cz/mentors/landa
Thanks Martin,
I meant a flag in the module.
Yann
On 3 February 2017 at 10:11, Martin Landa <landa.martin@gmail.com> wrote:
the CLI/SHELL?
d.mon wx0
d.rast …
d.vect …
Ma
Martin Landa
Yann Chemin
Planetary Scientist
Latest: https://peerj.com/preprints/2124/
JRC: https://www.thefreelibrary.com/3628±+CANHEMON+Remote+sensing+based+forest+canopy+health+monitoring…-a0453990005
OSGeo: https://wiki.osgeo.org/wiki/Open_Monitoring_Systems_Working_Group
2017-02-03 10:40 GMT+01:00 Yann Chemin <dr.yann.chemin@gmail.com>:
flag of the module? Which module? Ma
Martin Landa
say all raster and imagery and vector modules that generate output map(s), I would like this(ese) map(s) to be added to the current stack in the current display, the same way it works in the GUI version of the modules (i.e. Check-box “Add created maps to layer tree”).
Martin Landa
Yann Chemin
Planetary Scientist
2017-02-03 11:04 GMT+01:00 Yann Chemin <dr.yann.chemin@gmail.com>:
Check-box "Add created maps to layer tree").
so, something like:
# new flag -a: Add new maps to display automaticaly
d.mon wx0 -a
v.random out=p1 n=1000 # new map added to display
But in this case you cannot control display parameters
(d.vect/d.rast). There is no layer tree to define properties
afterwards. I am not sure if such flag would make sense.
Now you need:
d.mon wx0
v.random ...
d.vect p1 ...
Ma
Martin Landa
yes this is indeed a pickle.
maybe something like:
→ d.mon “get the selected wx display, if none, then d.mon wx0”
if exist and selected:
add output from this module to its “stack” (i.e. set of already run d.* commands)
→ v.random in=bla.vect out=blaout.vect -a
the -a flag in the module would take the actual selected monitor history of d.* commands and add one line with the “d.vect blaout.vect” at the end, and run the new history in it.
so, something like:
d.mon wx0 -a
Now you need:
d.mon wx0
v.random …
d.vect p1 …
Ma
Martin Landa
Yann Chemin
Planetary Scientist
