[GRASS-dev] Added suppress_required field to flags
"struct Flag" now has a boolean ->suppress_required field. If this
field is set on a flag, and that flag is given on the command line,
the parser won't check whether ->required options were provided.
This will allow options which are normally required to be marked as
required even if there are special cases which override this
requirement, e.g. a -l (list) flag or other "alternate mode" flags.
However, this feature cannot be used until the GUI's own requirement
checking has been adapted to understand it. Currently, if an option
marked as ->required is omitted but a flag marked as
->suppress_required is given, the command itself won't complain about
the missing option but the GUI will.
The field is included in the --interface-description output; the GUI
just needs to be updated to make use of it.
field. If this field is set on a flag, and that flag is given
on the command line, the parser won't check whether ->required
see also
  https://trac.osgeo.org/grass/ticket/886
that would help avoid some currently "required" options from
actually being set as required. presently some are set as
such just to get the option onto first tab of the GUI. (grumble)
quote:
I propose guisection->_("main") (important|core|primary|...?) as the first module wxGUI tab, which
    * Required=YES options are automatically assigned to,
    * and other options can be assigned to it as needed...
the Required tab while usually doing the right thing, is too blunt an instrument for all cases.
also this allows to have input= or output= on the front tab even if it can be optional due to a flag that prints some info to the terminal and exits. Forcing users to specify output=dummy to overcome Req=YES + --list style flags isn't a very nice solution, when Req=YES is just there to force the important option on to the front tab for visibility.
any more thoughts on this? ie some way to get around some of the wx module gui usability problems when none of the module's options are (nor should be) required, or some important non-required ones are hidden away in less obvious tabs.
I fear for things like m.proj that default to input=stdin that the best solution from the gui will ultimately be a wrapper script that forces it to require a real file.
with enough control, we don't have to compromise between focusing
module interfaces to favour GUI or CLI users, as we do now.
thanks,
Hamish
2010/11/25 Glynn Clements <glynn@gclements.plus.com>:
done in r44422.
Martin
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
done in r44422.
Okay. If people know of more cases where options are being listed as
->required=NO for the sake of special cases, or where certain flags
require option=dummy to satisfy the requirements, please mention them
(or fix them). There isn't any way to identify such cases
mechanically.
The situation with g.mapsets will require a more complex solution,
i.e. some way to inform the parser that at least one option from a set
is required.
One possibility is to allow the module to supply a boolean expression
involving option/flag names which must evaluate to true. This would
allow all of:
+ At least one of ... must be given
+ At most one of ... must be given
+ If ... is given, ... must also be given
+ If ... is given, ... must not be given
However, a more restrictive form might be more useful to the GUI.
Specifically, one or more lists of alternatives, where each
alternative identifies a primary flag/option, along with any
constraints on other options. This would allow a group of radio
buttons to be attached to the primary options.
E.g. for g.mapsets, the mapset=, addmapset= and removemapset= options
would form a group (along with the -s flag and possibly the -l flag).
So the user would be able to select exactly one of them, and the
others would be greyed out.
