works fine in the command line. Testing the modules wx-GUI (G70), doesn't play nice. For exampe,
the following WARNING (error) appears:
WARNING: Illegal filename <12DEC02053035.blue@python_scripting.hpf>. Character <@> not allowed.
WARNING: <12DEC02053035.blue@python_scripting.hpf> is an illegal file name
The "suffix" is added after the Mapset's name(string). Is there no option to "fix" this? Should I "fix" this in my code directly, i.e. take the string, split-off the Mapset-part, put in the suffix and add the Mapset's name in the end?
name in the end?
I would say you have to expect that your input map may have mapset, test
it, split if necessary and add suffix to the map name, but you might not
need to add the mapset again to the name.
Using the following in a python script's header:
#%option
#% key: outputsuffix
#% key_desc: suffix string
#% type: string
#% description: Suffix for the Pan-Sharpened image(s)
#% required: yes
#% answer: hpf
#%end
and somewhere in the script the following:
run("g.rename", rast=(tmp_msx_hpf,"%s.%s" % (msx, outputsuffix)))
play nice. For exampe, the following WARNING (error) appears:
name in the end?
Thanks Anna.
Is there a pygrass function to isolate the a raster map's basename from the Mapset part? Looking for it...
from grass.pygrass.raster.abstract import Info
images = {}
for img in imglst: # Retrieving Image Info
images[img] = Info(img, mapset)
images[img].read()
