-------- Original Message --------
Subject: Re: [GRASS-dev] Adding hexagonal rasters to GRASS
Local Time: July 25, 2017 5:46 PM
UTC Time: July 25, 2017 3:46 PM
To: Luís Moreira de Sousa luis.de.sousa@protonmail.ch
Vaclav Petras wenzeslaus@gmail.com, grass-dev@lists.osgeo.org grass-dev@lists.osgeo.org
Dear Luís,
2017-07-25 15:50 GMT+02:00 Luís Moreira de Sousa luis.de.sousa@protonmail.ch:
Hi Sören, good to have you in this discussion.
I do not know exactly what the compressed row approach is, but I am pretty
positive on it being applicable to hexagonal rasters too. As I wrote
initially, an hexagonal mesh can be stored in an array; from then on it is
all a matter of cell indexation.
The compressed row approach is used by GRASS GIS to store raster layer.
Each row of a raster map is stored as a compressed array. If you want
to access a single cell, you have to read the whole row that contains
the cell and uncompress it to access the cell. Many algorithms in
GRASS are programmed to access
raster layer maps by reading the first row and iterate over all cells,
then read the next row and iterate over all cells, … . Rows are read
from top to bottom, or North to South, cell are read from west to
east. This approach has pro and cons. It allows to skip reading rows
in case of on the fly resampling for visualization and makes
visualization very fast for large raster maps.
My understanding of hexagonal grids, that is derived from this:
http://www.redblobgames.com/grids/hexagons/
So i assume that North-South orientation is equal to a horizontal aka
pointy topped orientation.
The horizontal orientation is supported in GRASS by the compressed row
approach out of the box. A single row of hexagons can be stored as
compressed raster row. Then you can use the odd-r index scheme to
address the cells in the compressed rows as hexagons. Using the odd-r
indexing means that each row with an odd index is shifted by half a
hexagon to the east.
This approach makes it easy to process hexagonal grids with existing
raster modules. The on the fly nearest neighbor resampling algorithm
in GRASS can also be modified easily. Raster to hexagon and vice versa
conversion must be solved by a statistical resampling algorithm.
The raster display library must be improved to draw hexagonal grids,
or use its vector polygon draw routines, so that the d.rast tools can
be used for visualization. AFAIU the display library draws a
rectangles for each cell and fills it with a color.
Best regards
Sören
I added the angle rotation to the HexASCII specification since there are two
ways to align an hexagon with the Cartesian axis: with two sides parallel to
the x axis (North-South orientation) or with two sides parallel to y axis
(East-West orientation). With an angle of 0º in HexASCII you get a
North-South mesh, with 90º it is a East-West mesh. If other angles
complicate matters, on a first approach only angles of 0º and 90º could be
considered.
In any case, rotating a mesh by an angle is a relatively simple computation,
you can see an example in this method of the hex-utils package:
https://github.com/ldesousa/hex-utils/blob/develop/hex_utils/hasc.py#L235
During my MSc thesis I developed a method to display hexagons in a squared
monitor with bitmaps that may be still useful for the d. modules. But
perhaps a vector approach is more interesting today.
Cheers.
Im Grund 6
CH-8600 Dübendorf
Switzerland
Phone: +41 (0)79 812 62 65
Email: luis.de.sousa@protonmail.ch
URL: https://sites.google.com/site/luismoreiradesousa
Local Time: July 24, 2017 9:24 PM
UTC Time: July 24, 2017 7:24 PM
To: Vaclav Petras wenzeslaus@gmail.com
Luís Moreira de Sousa luis.de.sousa@protonmail.ch,
Dear Luís,
this sounds very interesting, especially the improvement for surface
flow algorithms using hexagonal grids and other mass conservation
approaches like groundwater flow, heat flow, … .
I agree with Vaclav on this topic. I think hexagonal grids can be
stored using the compressed row based approach of GRASS GIS. In
addition the rotation of the hexagonal grid may be stored in the
metadata. The question is, do we need rotated hexagonal grids at all
or do horizontal hexagonal grids do the job? In case of “horizontal”
hexagonal grids the compressed row approach would be very fast for
horizontal access. Indexing can be easily mapped to row/column access
using the “odd-r” horizontal layout. The existing on the fly nearest
neighbor resampling algorithms will have an offset of half a cell for
odd row indices when interacting with normal raster layers in existing
modules, so they must be adjusted.
Neighborhood operations must be implemented on top of the existing
row/col approach of GRASS. All algorithms that make cell neighbor
computations must be modified. The existing r.mapcalc neighbor
operators r[y] can be reused in case of odd-r horizontal layout.
Conversion between regular grids and hexagonal grids must be
implemented. Resampling algorithms must be modified. Rendering of
hexagonal grids must be implemented in the display library. Plenty of
work do do.
Best regards
Sören
2017-07-24 1:19 GMT+02:00 Vaclav Petras wenzeslaus@gmail.com:
Dear Luís,
On Sun, Jul 23, 2017 at 11:50 AM, Luís Moreira de Sousa
luis.de.sousa@protonmail.ch wrote:
I presented hex-utils at the GISTAM conference in April, here is the
video:
https://www.youtube.com/watch?v=uLO4HDCVBp0
thank you, this is very informative and exiting!
But as Luca said during the Q/A, it is probably better to start outright
within GRASS. This will require the abstraction of the raster concept,
together with operations like neighbourhood, number of neighbours,
distance
to neighbours, etc. With that done most of the raster modules would
function
the same way for squared and hexagonal rasters. Still, this would require
a
complete revision of all the raster modules.
Sounds good. I think there is a way in GRASS GIS to make it revolutionary
and at the same time keeping everything in place. See below.
For a programmer, the main difference between hexagonal and squared
rasters is the cell addressing system: with hexagons the axis are not
orthogonal.
If there would be a way, like the abstraction you mentioned, which would,
e.g. make the current rectangle-only code work with hexagonal data (e.g.
by
presenting converting hexagons as rectangles on the fly), that would be
helpful, but on the other side, I don"t think it is necessarily the first
step if there is an other way how to connect with rectangular rasters
(even
if it involves converting back and forth or less precision).
However, it is possible to store an hexagonal raster in a bi-dimensional
array like you would store a squared raster.
That would help the implementation and hopefully also the integration and
adoption, again see below.
I wrote an article last year with full details on the HexASCII file
format
and how to deal with hexagonal cell adressing, but it is still under
review.
I can not send it to the list, please send me a personal message if you
wish
to read it.
If you can share it, I would like to see it.
It would be great if we can take this forward. I imagine it is a load of
work, but it will make GRASS an even more awesome system
Load of work and resulting code to maintain should be part of the
consideration. Using existing functionality (algorithms, formats) and
integrating with it will be crucial for both users and developers alike.
Can you implement it this as a layer on top of existing functionality in
GRASS GIS? There is several examples and concepts in GRASS GIS of this.
For
example, the temporal (t.*) modules work with series of rasters and
vectors
registered as spatio-temporal datasets and the image processing (i.*)
modules work with series of rasters registered as imagery groups and
subgroups (“multiband image”). In both cases standard storage of rasters
(or
vectors) is used, so there is no new backend format in GRASS database
except
for the additional data (metadata) needed for these tools. What is
important
is that you can work with the existing tools on the data handled by
temporal
or imagery modules, i.e. you can use the existing tools to implement the
new
tools (e.g. average of spatio-temporal raster dataset can be implemented
through a tool for average of multiple rasters) and if the imagery or
temporal modules miss specific functionality you need, you can fallback to
the standard modules (e.g. loop over members of imagery group).
I was thinking that the hexagonal rasters can be implemented in GRASS GIS
using two rasters which would be shifted against each other, but aligned
with the hexagonal cells, i.e. two rectangular rasters making up one
hexagonal raster/grid (but I didn"t test that or examined that more).
After
seeing your video with slightly rotated hexagonal grid, I"m thinking if it
is possible to fit only one raster but with different resolution to the
hexagons. The idea is that 1) you don"t need another storage format and 2)
you can use the raw data without the hexagon-aware algorithms. Of course
we
can settle just with re-using the storage format (1).
Another approach is to threat hexagonal rasters/grids as another basic
data
type next to raster maps, vector maps, and 3D raster maps (in GRASS GIS
there are also the aforementioned spatio-temporal datasets and imagery
groups). They would be connected to the rest where it makes sense. For
example, (2D) rasters and 3D rasters are independent, but there is also
several connections: there are modules for conversion in between the two
types, a lot of code for handling colors is the same, and computational
region applies to both and is handled from the same module.
If I may ask, what would you need to create a prototype and what do you
envision as a final goal?
Best,
Vaclav
grass-dev mailing list
https://lists.osgeo.org/mailman/listinfo/grass-dev
