[GRASS-dev] Adding path iconv library to ./configure
Dear all,
In order to compile in a conda environment (where iconv is installed through conda, not in the system), I’m trying to add a path to icon into ./configure(.in). The issue is that although GRASS happens to configure properly, the compilation fails because libiconv.* is not found.
I have added code which is used for other libraries, although I’m not sure what exactly should I do for a mandatory dependency. The part which seems to be failing is AC_CHECK_FUNC.
ac_save_ldflags=“$LDFLAGS”
LDFLAGS=“$LDFLAGS $ICONVLIBPATH”
LDFLAGS now contains the path set using --with-iconv-libs
AC_CHECK_FUNC(iconv, ICONVLIB=, [
AC_CHECK_LIB(iconv, iconv, ICONVLIB=-liconv, [
AC_CHECK_LIB(giconv, iconv, ICONVLIB=-lgiconv, [
AC_CHECK_FUNC(libiconv, ICONVLIB=, [
AC_CHECK_LIB(iconv, libiconv, ICONVLIB=-liconv, [
AC_CHECK_LIB(giconv, libiconv, ICONVLIB=-lgiconv, [
AC_MSG_WARN([*** Unable to locate iconv() function.])
ICONVLIB=
AC_SUBST(ICONVLIB)
LDFLAGS=“${ac_save_ldflags}”
The AC_CHECK_FUNC step above seems to succeed
The output is “checking for iconv… yes”
The step below fails because $ICONVLIB is empty
With “checking for iconv in -l… no”
LOC_CHECK_LIBS($ICONVLIB,iconv,iconv,$ICONVLIBPATH,ICONV,)
I’m including a full diff too. Note that the iconv library is different from the others because our ./configure allows for different names of the library.
Alternative would be to use LDFLAGS. That would be actually ideal, because all libraries are just at one common prefix. However, providing it as a parameter to ./configure (which seems to be the recommended way even over the above) results in “unknown platform” and providing it as an environmental variable does not have any effect.
Please, let me know if you have any advice,
Vaclav
(attachments)
iconv_path_in_configure.diff (1.67 KB)
On Wed, Feb 26, 2020 at 5:35 PM Vaclav Petras <wenzeslaus@gmail.com> wrote:
Dear all,
it seems that GRASS configure uses iconv from libc if present, but at compile time this is not always true: sometimes iconv from libiconv is attempted to be used and not from libc.
See https://lists.osgeo.org/pipermail/grass-dev/2014-December/072690.html
Most importantly, regarding only iconv:
“In the configure script, the header checks and the library checks are
disconnected.”
This needs to be fixed.If the configure checks pass, the settings used by configure (included headers, linkied libraries) need to be used as compile time.
Markus M
ICONVLIB=
AC_SUBST(ICONVLIB)
Vaclav
grass-dev mailing list
grass-dev@lists.osgeo.org
https://lists.osgeo.org/mailman/listinfo/grass-dev
