[GRASS-dev] adding units and vertical datum metadata to raster maps
(wish #392)
I have hacked together the attached code to add units and vertical datum
metadata to raster maps. It still needs some cleanup before going into
CVS, but right now I am interested in comments on the approach taken.
[it works]
TODO: buffer overflow checking
TODO: create a fn in r.info to take care of G_asprint() work, right now
the "fancy output" section of the module is an ugly mess.
[non-functional code, due to me being lost WRT passing pointers]
        if (G_asprintf(&line, "Location: %s", G_location()) > 0)
            printline(line);
        else
            G_fatal_error(_("Cannot allocate memory for string"));
        compose_line( &line, "Location: %s", G_location() );
        printline(line);
void compose_line(char *line, const char *fmt, ...)
    va_list ap;
    line = NULL;
    va_start(ap, fmt);
    if( G_asprintf(line, fmt, ap) <= 0 )
    va_end(ap);
Hamish
(attachments)
meta_mods.diff (6.82 KB)
raster_metadata.c (2.36 KB)
Hello Hamish
On Wed, 9 May 2007, Hamish wrote:
(wish #392)
[it works]
I remember Helena saying something about wanting a module to be able to check what units an input raster map was in, so it could warn the user if there was a subtle error. But if the units are totally free-form then this is likely to be unreliable. I'm wondering if there is some kind of standard for specifying units in an ASCII text string, and if we should investigate this and add wrapper functions to these new functions that try to ensure the units are in a prescribed format where possible. Of course people could still put anything in using your functions directly, if they had special requirements. But perhaps the modules Helena identified as having a serious need for storing and checking units should have some higher level functions to do that for them?
G_asprintf() takes a pointer to a pointer for the first argument, and the compose_line() function takes a pointer for the first argument. But below compose_line is being passed a pointer to a pointer (& operator used on
something that was already a pointer) and G_asprintf() is only being passed a pointer. I think changing it so "line" is passed to compose_line and "&line" to G_asprintf would work.
           printline(line);
       else
       printline(line);
   va_list ap;
   line = NULL;
   va_start(ap, fmt);
   va_end(ap);
Hamish
Hamish:
> datum metadata to raster maps. It still needs some cleanup before
> going into CVS, but right now I am interested in comments on the
> approach taken. [it works]
units must be free form, as the possibilities are endless.
(for example I have many µg/l raster maps)
$ units
2084 units, 71 prefixes, 32 nonlinear units
^D
modules like r.slope.aspect can set "units=degrees" if they want,
and modules like r.shaded.relief and NVIZ can check, e.g.,
strcmp(tolower(units), "meters")
for hinting about scaling (Lat/Lon). I don't think it is practical to be
seriously checked, but it can be useful for hinting when available and
also for rendering d.legend and ps.map scale bar labels automatically.
Hamish
> now the "fancy output" section of the module is an ugly mess.
operator used on something that was already a pointer) and
work.
Nope, still doesn't work. main()'s "line" does not get updated, ie
pointer is not returned from compose_line(). In the output I see the
previous "Mapset:" line twice.
(new diff attached)
how/where to use G_free(line)? need to move printline(line) into
compose_line() to avoid having to repeat G_free() in main() for every
call to compose_line()?
Trying that approach (2.diff) and passing the output stream to
compose_line() mostly works, but then I get va_* stdarg errors:
thanks,
Hamish
(attachments)
rinfo_compose.diff (1.74 KB)
rinfo_compose2.diff (1.78 KB)
[it works]
            printline(line);
        else
        printline(line);
    va_list ap;
    line = NULL;
    va_start(ap, fmt);
This won't work; we need a G_vasprintf() function which takes a
va_list.
Move the body of G_asprintf() into G_vasprintf(), and implement
G_asprintf() as:
  int G_asprintf(char **out, const char *fmt, ...)
      va_list ap;
      int ret;
      va_start(ap, fmt);
      ret = G_vasprintf(out, fmt, va);
      va_end(ap);
      return ret;
> printline(line);
> else
> printline(line);
> va_list ap;
> line = NULL;
> va_start(ap, fmt);
va_list.
I've added G_vasprintf().
Hamish:
> > right now the "fancy output" section of the module is an ugly
> > mess.
Glynn:
r.info cleaned. Thanks.
I have now added in support for raster map units and vertical datum
metadatas in 6.3 cvs. Settable with r.support, viewable with r.info.
All other modules currently ignore these, it is expected that in future
modules like r.shaded.relief and NVIZ may use the units values for
conversion hinting in lat/lon locations, and modules like r.patch might
produce a warning if the units or vertical datums don't match. Both are
freeform in nature, so it is not recommended to code against them for
anything critical. (ie don't expect them to be set to anything already)
For now r.info will be quiet about units and vertical datum unless they
have been set.
I also added in r.support a couple new options to set other r.info
fields, and renamed the new organization= option to source1= (as now
there is a source2= too, and "data source" may well be a satellite
name or published dataset).
All non-interactive r.support options can now be used in one call to the
program as well.
Hamish
Any chance that vertical units will show up in g.proj? That's where your
current code grabs the horizontal units for display in measurement and
profiles (very nice in fact, so I'm redoing it in wxgrass too).
Michael
On 5/21/07 3:53 AM, "Hamish" <hamish_nospam@yahoo.com> wrote:
Hamish:
mess.
Glynn:
have been set.
program as well.
Hamish
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
Vertical units apply only to a particular map in a particular mapset, not to all the mapsets in a location like horizontal units (i.e. the location's co-ordinate system do). And it's perfectly valid to have different elevation maps in different units in the same mapset and to have to convert between them (e.g. ellipsoidal height from GPS and geoid height above sea level). I can't really see how the location co-ordinate system definition could easily be extended to support units for the 3rd dimension :confused:
Paul
This makes perfect sense. I didn't think it through.
Michael
Paul
Center for Social Dynamics and Complexity
phone: 480-965-6213
fax: 480-965-7671
