A related / similar issue, I have added an add-on https://trac.osgeo.org/grass/browser/grass-addons/grass7/raster/r.biodiversity and added it to the parent Make file. I can't recall having done anything else then just uploading an add-on in the past, but it is not available through g.extension, nor does it show up in the online manual pages. From the links mentioned above, I am not clear what else I should do, or whether I did something wrong during upload?
On Fri, Sep 11, 2015 at 1:13 PM, Paulo van Breugel <p.vanbreugel@gmail.com>
wrote:
PS: no idea what "WARNING: No addons metadata available. Addons
metadata file not updated." means
No clue either, but maybe the reason it doesn't show in the g.extension
GUI?
Well, I did pretty heavy changes in trunk's g.extension but I was not
getting this warning. It means that it can't find a particular XML on the
server. Does this happen for other addons or just r.biodiversity?
PS: no idea what “WARNING: No addons metadata available. Addons
metadata file not updated.” means
No clue either, but maybe the reason it doesn’t show in the g.extension GUI?
Well, I did pretty heavy changes in trunk’s g.extension but I was not getting this warning. It means that it can’t find a particular XML on the server. Does this happen for other addons or just r.biodiversity?
On Fri, Sep 11, 2015 at 1:37 PM, Paulo van Breugel <p.vanbreugel@gmail.com>
GUI?
It seems not, I just tried to (re) install two others (r.bioclim and
r.mess) and I did not get such warning
I don't know if the server-side XMLs are generated for 71 or just 70 but
probably they are. Then I can also see that the addons page [1] data in the
bottom is some completely old one (Út srp 18 means Tuesday, August 18).
Since it is happening just for the new addon, it might be just because of
some delay in generating all server side things; I always have the feeling
that there is some delay, although it should be just 24 max.
Just to add the note that those are add-ons that are already in the svn for some time, while r.biodiversity was just added. Not sure that makes a difference? Perhaps the XML file concerned is not renewed / updated?
It seems not, I just tried to (re) install two others (r.bioclim and r.mess) and I did not get such warning
Yes, that is it. When using the address, things work as expected, the addon appears in the list and no error message. Would it be possible to make this work for v71 as well?
I don’t know if the server-side XMLs are generated for 71 or just 70 but probably they are.
Then I can also see that the addons page [1] data in the bottom is some completely old one (Út srp 18 means Tuesday, August 18). Since it is happening just for the new addon, it might be just because of some delay in generating all server side things; I always have the feeling that there is some delay, although it should be just 24 max.
Yes, that is it. When using the https://svn.osgeo.org/grass/grass-addons/grass7/ address, things work as expected, the addon appears in the list and no error message. Would it be possible to make this work for v71 as well?
If someone tells me where, I can simply add a link on the server.
2015-09-12 7:39 GMT+02:00 Markus Neteler <neteler@osgeo.org>:
I don't know why, but addons logs were last time generated on 18/8.
Now I launched jobs manually and I didn't find any problem [1]. Also
r.biodiversity has metadata up-to-date now.
