Hi Martin,
since the switch to use G76 as the basis for the addon manual pages,
the two files
grassdocs.css
are no longer put onto the server.
I suspect that they are not picked up on the build server:
grass-addons/tools/addons/grass-addons-build.sh" line 38 of 59
cp ${SRC}/grass${1}${2}_release/${DIST}/docs/html/grassdocs.css $HTMLDIR/
cp ${SRC}/grass${1}${2}_release/${DIST}/docs/html/grass_logo.png $HTMLDIR/
Could you please verify?
thanks
On Wed, Apr 24, 2019 at 4:28 PM Markus Neteler <neteler@osgeo.org> wrote:
Hi Martin,
the two files
grassdocs.css
The reason is probably that the installation directory has been changed to include the bugfix release number in r74038, the culprit is probably the change in configure.in:L219 [0] which needs to be reverted.
Markus M
[0] https://trac.osgeo.org/grass/changeset/74038/grass/branches/releasebranch_7_6/configure.in
thanks
grass-dev mailing list
grass-dev@lists.osgeo.org
https://lists.osgeo.org/mailman/listinfo/grass-dev
st 24. 4. 2019 v 16:28 odesílatel Markus Neteler <neteler@osgeo.org> napsal:
yes, the reason is that G76 is not compiled on server due to a new
required dependency:
configure: error: *** Unable to locate zstd includes.
I will fix it ASAP. Ma
Martin Landa
http://geo.fsv.cvut.cz/gwiki/Landa
http://gismentors.cz/mentors/landa
On Thu, Apr 25, 2019 at 7:42 AM Martin Landa <landa.martin@gmail.com> wrote:
zstd is not a required dependency, you can disable it with --with-zstd=no
Markus M
Martin Landa
čt 25. 4. 2019 v 7:56 odesílatel Markus Metz
<markus.metz.giswork@gmail.com> napsal:
right, I meant "by default enabled dependency"
Ma
Martin Landa
čt 25. 4. 2019 v 7:41 odesílatel Martin Landa <landa.martin@gmail.com> napsal:
fixed, see eg. https://grass.osgeo.org/grass76/manuals/addons/db.join.html
Ma
Martin Landa
On 25/04/19 07:56, Markus Metz wrote:
On Thu, Apr 25, 2019 at 7:42 AM Martin Landa <landa.martin@gmail.com <mailto:landa.martin@gmail.com>> wrote:
> Hi,
> st 24. 4. 2019 v 16:28 odesílatel Markus Neteler <neteler@osgeo.org <mailto:neteler@osgeo.org>> napsal:
This is the issue I raised with #3815. I don't think it is a good idea to use something as default if it is not a required dependency. As I described this can lead to the issue that without the user knowing it (e.g. using GRASS GIS that was compiled by someone (package manager, etc) with --with-zstd=yes) she creates raster maps that are compressed with zstd. If these maps are then moved to a machine that doesn't have zstd, the data is unusable.
That is why I proposed to make it a requirement. The other alternative, IMHO, would be to make ZLIB the default compression again and leave the use of ZSTD to power users.
Moritz
