[GRASS-dev] Adios!
Hi.
I am leaving GRASS project and I have summarized my ideas on vector
library and modules in GRASS in this document:
http://freegis.org/cgi-bin/viewcvs.cgi/*checkout*/grass6/doc/vector/TODO?rev=HEAD&content-type=text/plain
I'll continue to work on QGIS and GRASS plugin in QGIS.
I won't be able to work in GRASS PSC but I'll follow the process of
PSC constitution and I'll do everything I can to ensure that PSC and
decision making procedures will be democratic and it will take into
account everybody who is working on GRASS (I mean vote for all
contributors and clear majority).
Adios!
Radim
Hasta Luego...
Thanks really a lot,
ginetto
Radim Blazek wrote:
Hi.
Adios!
Radim
ATTENZIONE: le informazioni contenute in questo messaggio sono da considerarsi confidenziali ed il loro utilizzo e' riservato unicamente al destinatario sopra indicato. Chi dovesse ricevere questo messaggio per errore e' tenuto ad informare il mittente ed a rimuoverlo definitivamente da ogni supporto elettronico o cartaceo.
WARNING: This message contains confidential and/or proprietary information which may be subject to privilege or immunity and which is intended for use of its addressee only. Should you receive this message in error, you are kindly requested to inform the sender and to definitively remove it from any paper or electronic format.
Thanks Radim for all you've done for us.
pc
At 11:57, mercoledì 24 maggio 2006, Radim Blazek has probably written:
Hi.
I am leaving GRASS project ...
Paolo Cavallini
email+jabber: cavallini@faunalia.it
www.faunalia.it
Piazza Garibaldi 5 - 56025 Pontedera (PI), Italy Tel: (+39)348-3801953
My great thanks to you for your significant contributions.
Huidae Cho
On Wed, May 24, 2006 at 11:57:52AM +0200, Radim Blazek wrote:
Hi.
Adios!
Radim
grass-dev mailing list
grass-dev@grass.itc.it
