But if people don't even have the time to spell out "you",
then how do we expect them to find the resources it takes
to read a whole message on screen?
Please: if something goes wrong then sit back for at least
10 secs, maybe have a tea, look at it again, make sure you
tried your best to fix it.
THEN write to this list.
This is software development, not Twitter.
Best,
Ben
----- Original Message -----
sunil wrote:
> the following compilation log came , , can u explain
> what should i do next
> GRASS GIS compilation log
> ------------------------- Started compilation: Wed Sep 29 11:21:01
> IST 2010
> Errors in:
> /usr/local/src/grass-6.4.0/lib/gis
> --here you go:
> In case of errors please change into the directory with error and
> run 'make'.
> If you get multiple errors, you need to deal with them in the order
> they appear in the error log. If you get an error building a
> library, you will
> also get errors from anything which uses the library.
> -- Finished compilation: Wed Sep 29 11:47:57 IST 2010for WinGrass see also
https://trac.osgeo.org/grass/wiki/CompileOnWindowsHamish
_______________________________________________ grass-dev mailing list
grass-dev@lists.osgeo.org
Files attached to this email may be in ISO 26300 format (OASIS Open Document Format). If you have difficulty opening them, please visit http://iso26300.info for more information.
