I’ve noticed that the ampersand character is interpreted strangely when it is in the guisection property of module option, e.g.:
#% guisection: Files & format
is added for the following options in the m.proj module
G_OPT_F_INPUT
G_OPT_F_OUTPUT
G_OPT_F_SEP
However, the resulting section in the wxGUI generated module form/dialog is Files format. Is & interpreted in some special way, e.g. for translation? I was not exploring this more since the number of involved parts is high and I hope that someone might have better overview.
Moreover, if you look at the generated form you can see that input is still in required, although G_OPT_F_INPUT has guisection specified. This seems that unless you explicitly specify required: no guisection is ignored.
I must say that I was not even trying to find some documentation for this since these things are usually under-documented. Thus I don’t know if this behavior is bug or a feature.
My guess without reading any documentation/code. & is a common
indicator for accelerator key in GUI strings (i.e. "&File" to make
alt+F to work). As --interface-description contains & i.e. "Files
& format", I would bet on that.
Maris.
2013/10/9 Vaclav Petras <wenzeslaus@gmail.com>:
I've noticed that the ampersand character is interpreted strangely when it
is in the `guisection` property of module option, e.g.:
G_OPT_F_INPUT
G_OPT_F_OUTPUT
G_OPT_F_SEP
`Files format`. Is & interpreted in some special way, e.g. for translation?
Moreover, if you look at the generated form you can see that `input` is
seems that unless you explicitly specify `required: no` guisection is
ignored.
since these things are usually under-documented. Thus I don't know if this
