Dear all, apologies for silence (I have to answer to a couple of threads in
grass-dev) but I am overloaded. This is however a quick idea that crossed my
mind a few seconds before as I am working with the newest g.gui.mapswipe tool:
(Anna & Vaclav) wouldn't it be useful to have some sort of export of the
(raster) layers loaded in the Advanced mode (order matters!) to feed with the
r.patch module? Or directly a "Patch" function (interfacing the r.patch
module)?
Say, I have, in one of the panes (left or right, doesn't matter), from bottom
to top a generic Vegetation map (including let's say high and low vegetation),
a Water Map and on top a High Vegetation map (derived from another source) and
I want to patch these maps: 1st the High Vegetation map, the Water, then
whatever is NULL fill with data from the generic Vegetation map. Just a random
examlpe to make a point.
Makes sense?
Thank you, Nikos
