I’ve made a lot of progress getting your TclTk replacement for Xganim into the GUI. However, I haven’t been able to make it animate anything. I finally tracked this down to the line…
This requires a program pnmscale. I don’t have pnmscale. Does it comes with GRASS and I somehow don’t have it or is it a 3rd party program?
Michael
Director of Graduate Studies
Arizona State University
I've made a lot of progress getting your TclTk replacement for Xganim into the GUI. However, I haven't been able to make it animate anything. I finally tracked this down to the line...
Also I found in the pnmscale manual:
pnmscale was obsoleted by pamscale, introduced with Netpbm 10.20 (January 2004)
I have it on RedHat linux box but I don't have it on Mac or Ubuntu so apparently you have to install it yourself.
Helena
Michael
Check the source/macosx readme. I have build instructions there for the netpbm tools source (it's an annoying one to build). Knowing this tool is needed, I'll add it to my bundling for binaries when you get the xganim.tcl working (I already bundle a few other netpbm tools for other GRASS modules).
On Sep 8, 2007, at 5:26 PM, Michael Barton wrote:
Glynn,
[Trillian] What are you supposed to do WITH a maniacally depressed robot?
[Marvin] You think you have problems? What are you supposed to do if you ARE a maniacally depressed robot? No, don't try and answer, I'm 50,000 times more intelligent than you and even I don't know the answer...
I thought that of the (main?) goals of doing a TclTk animation replacement
for Xganim was so that we no longer needed motif/lesstif as a GRASS
dependency. While the TclTk animator is nicer looking than xganim, if
pnmscale is required, we just replace one dependency with another one. Maybe
there is another way to do this???
Michael
Glynn,
robot?
answer...
- HitchHiker's Guide to the Galaxy
some netpbm tools are already needed by a couple other script modules, so it's not a new requirement. But it seems it is not mentioned in the GRASS requirements.
This requires a program pnmscale. I don't have pnmscale. Does it comes with
GRASS and I somehow don't have it or is it a 3rd party program?
xganim.tcl can probably be modified to rescale the image itself, using
the -zoom and -subsample options to the "copy" image command (see the
photo(n) manpage), but that will probably be slower than using
pnmscale.
Also, I don't think that those options can be combined, so you would
have to zoom the image first then subsample the zoomed image. One
consequence is that it may not be practical to get the exact size
required (the zoom factor needs to be reasonably small to avoid
creating a huge intermediate image).
If the lack of pnmscale is the only issue, I can create a local
version.
The main question is whether the Tcl/Tk version is fast enough to act
as a replacement for xganim. When I originally posted it, the comments
suggested that the speed difference was enough that xganim needed to
be retained.
replacement
one. Maybe
- revised entry in the HitchHiker's Guide to the Galaxy
I played around with TclTk rescaling a little when initially working out how
to display GRASS maps in a Tcltk canvas and was disappointed in how it
worked--especially quality.
version.
This would be especially good for Windows users. Maybe just build it into
r.out.ppm???
be retained.
I was wondering this too. I'd originally thought that the best way to go
about this was to render all the maps to PPM first, and then display the
animation in a second step. But I was able to get the TclTk animation
running without scaling so that I could continue to get the rest of it
working. I'm surprised at how fast it runs. The maps I'm testing are very
simple. Is the speed of r.out.ppm affected by the amount of non-null data or
just the total number of cells? If the latter, then it may well be quite
fast enough.
Michael
Do you have a list? netpbm is rather fat; especially if
you only want a few lines of code from it.
d.out.gpsdrive: pngtopnm, pnmtojpeg
r.out.mpeg: ppmtompeg (but can also use mpeg_encode instead)
xganim.tcl: pnmscale
NetPBM is also mentioned in:
drivers/HTMLMAP
drivers/PNG
NVIZ
r.in/out.gdal (as a format)
r.out.ppm
r.texture
These are the ones I've found so far (searching for 'netpbm'):
ppmtompeg: r.out.mpeg
This is bound to require some kind of external tool, be it ppmtompeg,
mencoder (from mplayer), etc.
pngtopnm: d.out.gpsdrive
This is gratuitous. The PNG file is generated by the PNG driver, which
can generate PPM files by itself. Moreover, the ability to generate
PPM files is unconditional, while generating PNG files is optional
(using --without-png will disable it). The "PNG driver" name is a
historical artifact.
pnmtojpeg: d.out.gpsdrive
This will require an external utility, but "cjpeg" would have been a
better choice. "cjpeg" is built and installed along with libjpeg,
which pnmtojpeg requires. IOW, if you have pnmtojpeg, you already have
cjpeg, but the reverse isn't true.
pnmscale: xganim.tcl
xganim.tcl was something I hacked together in an hour to determine the
feasibility of replacing xganim. AFAICT, it isn't actually part of
GRASS (yet).
> version.
r.out.ppm???
You can achieve the same result by running r.out.ppm with a different
region resolution.
I'm not sure why I didn't do that in xganim.tcl.
It's affected by the speed of G__lookup_colors(), which has an
optimisation for runs of a single value: if the value matches the
previous value, it uses the previous colour. This can be significant
for FP maps, where you can't create a lookup table, but have to locate
and interpolate the appropriate colour rule.
GRASS (yet).
This won't need pnmscale. Glynn's solution to do scaling via adjusting the
resolution prior to running r.out.pnm works fine.
Michael
Center for Social Dynamics and Complexity
