Here is another issue with an infurating problem of parameter pairs.
I have input map names saved to a set of variables.
I want to do the following:
grass.run_command('g.copy ', raster=[variable],[mapname])
The output [mapname] can be a string for a mapname or a previously defined variable containing the mapname.
I’ve looked at the docs for the scripting and python libraries and nothing there helps. I consistently get a file not found error or a syntax error if I try to use string substitution.
Michael
C. Michael Barton
Head, Graduate Faculty in Complex Adaptive Systems Science
Arizona State University
voice: 480-965-6262 (SHESC), 480-965-8130/727-9746 (CSDC)
fax: 480-965-7671 (SHESC), 480-727-0709 (CSDC)
www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu
